Software Archive
Read-only legacy content
17060 Discussions
__MIC__ macro does not work
wang_p_1
Hello everyone,
           To solve problems like this:   undefined reference to `_mm512_xxx_xxx(), I have added __MIC__ macro into my code.(https://software.intel.com/en-us/comment/1726413#comment-1726413)
          But, these code between the
#ifdef __MIC__
xxxx
xxxx
#endif
         never won't be executed.
         _________________________________________________________________________________
        as the picture showing , the printf() fucntion never won't be executed.
              Thank you!
Kevin_D_Intel
Use of __MIC__ inside the pragma offload is not supported. The compiler does not enforce this restriction so the programmer needs to be aware of and avoid this,  otherwise it can lead to problems with what the compiler sees for the host and target compilations. For more info see: Restrictions on Offloaded Code Using a Pragma
In this case, there are some missing/mis-placed curly-braces within the #ifdef/else/endif construction that lead to the unexpected results. As written the #ifdef/endif is not completely enclosed inside the pragma offload construct which leads the unexpected results.
The function f1 should be modified as shown below.
void point::f1()
#pragma offload target(mic:0)
#ifdef __MIC__
        for(int i = 0; i < 20; i++)
        {                                                 // Add this missing curly brace to for loop
             printf("I'm mic\n");
             fflush(0);
#else
//}                                                       // this curly brace is mis-placed - it should appear after the #endif below
        printf("I'm CPU\n");
#endif
}                                                         // place curly brace here to enclose ifdef block in offload construct
With those changes the program runs as expected. Also, just a note, the __declspec(target(mic:0)) syntax does not include the target id, so this only needs to be: __declspec(target(mic))  For more info, see: Placing Variables and Functions on the Coprocessor
Hope that helps.
wang_p_1
In order to simplify this problem, I have simulated the runtime environment.
#head.h
class point{
	public:
	point(){}
	void f1();
	void f2();
#head.cpp
#include"head.h"
#include"stdio.h"
__declspec(target(mic:0)) __forceinline void print()
#ifdef __MIC__
	printf("I'm monkey\n");
	fflush(0);
#else
	printf("I'm dog\n");
	fflush(0);
#endif
void point::f1()
#ifdef __MIC__
	fflush(0);
#else
#endif
void point::f2()
	print();
#main.cpp
#include"head.h"
int main()
	point p;
	p.f1();//output "I'm CPU". but without "I'm mic"
	p.f2();//output "I'm monkey".It's ok,mic print this.But why??
return 0 ;
$icpc -V
//14.0
$icpc head.cpp main.cpp -o main
$./main
//I'm cpu
//I'm monkey
__________________________________________________________________________________
but why class point member fucntion f1 can not print out "I'm mic" ??
this is an interesting topic, isn't it?  ^.^
thank u !
Kevin_D_Intel
void point::f1()
#ifdef __MIC__
             fflush(0);
#else
#endif
Hope that helps.
wang_p_1
It does work well.
 thanks very much.
void point::f1()
#ifdef __MIC__
             fflush(0);
#else
#endif
Hope that helps.
Kevin_D_Intel
Great. You're welcome.
wang_p_1
after reading these information, we get this conclusion:
"Do not use the __MIC__ macro inside the statement following a #pragma offload statement."
thanks your link, it's really useful !
void point::f1()
#ifdef __MIC__
             fflush(0);
#else
#endif
Hope that helps.
