Software Archive
Read-only legacy content
공지
17060 토론
Power for multiple Xeon Phi cards
Minh_H_
초급자
658 조회수
System:  Ubuntu 14.01 LTS, MPSS 3.4.1
We have a server with 2KW power supply, which the manufacture claims support up to 6 Xeon Phi Cards.
When I run my program on Xeon Phi (31S1P) uses all the cores (100% core utilization). I see the power usage on each card is about 188  Watts, which is much lower than 275W in the Xeon Phi specification sheet. I wonder if I can plug all 6 Xeon Phi 31S1P card to the server. What should I check to make sure the system is not under power?  In case the system is under power, is there any damage to CPU and GPU?
0 포인트
2 응답
TaylorIoTKidd
새로운 기여자 I
658 조회수
This question is best left to the company that sold you hour host system. They designed it, know all the specifications and capabilities, and warrantied it.
Taylor
0 포인트
Aleksandr_S_1
초급자
658 조회수
a 'proper' power supply will just shutdown.  does it have certification? like gold/platinum etc? assume platinum has better components and better probability to achieve rated wattage
so I'd just plug all 6 in and see if it works..
0 포인트
응답
