Hello everyone,
To solve problems like this: undefined reference to `_mm512_xxx_xxx(), I have added __MIC__ macro into my code.(https://software.intel.com/en-us/comment/1726413#comment-1726413)
But, these code between the
#ifdef __MIC__
xxxx
xxxx
#endif
never won't be executed.
_________________________________________________________________________________
as the picture showing , the printf() fucntion never won't be executed.
Thank you!
Use of __MIC__ inside the pragma offload is not supported. The compiler does not enforce this restriction so the programmer needs to be aware of and avoid this, otherwise it can lead to problems with what the compiler sees for the host and target compilations. For more info see: Restrictions on Offloaded Code Using a Pragma
In this case, there are some missing/mis-placed curly-braces within the #ifdef/else/endif construction that lead to the unexpected results. As written the #ifdef/endif is not completely enclosed inside the pragma offload construct which leads the unexpected results.
The function f1 should be modified as shown below.
void point::f1() { #pragma offload target(mic:0) { #ifdef __MIC__ for(int i = 0; i < 20; i++) { // Add this missing curly brace to for loop printf("I'm mic\n"); fflush(0); } #else //} // this curly brace is mis-placed - it should appear after the #endif below printf("I'm CPU\n"); #endif } // place curly brace here to enclose ifdef block in offload construct }
With those changes the program runs as expected. Also, just a note, the __declspec(target(mic:0)) syntax does not include the target id, so this only needs to be: __declspec(target(mic)) For more info, see: Placing Variables and Functions on the Coprocessor
Hope that helps.
链接已复制
In order to simplify this problem, I have simulated the runtime environment.
#head.h
class point{ public: point(){} void f1(); void f2(); };
#head.cpp
#include"head.h" #include"stdio.h" __declspec(target(mic:0)) __forceinline void print() { #ifdef __MIC__ printf("I'm monkey\n"); fflush(0); #else printf("I'm dog\n"); fflush(0); #endif } void point::f1() { #pragma offload target(mic:0) { #ifdef __MIC__ for(int i = 0; i < 20; i++) printf("I'm mic\n"); fflush(0); } #else } printf("I'm CPU\n"); #endif } void point::f2() { #pragma offload target(mic:0) { print(); } }
#main.cpp
#include"head.h" int main() { point p; p.f1();//output "I'm CPU". but without "I'm mic" p.f2();//output "I'm monkey".It's ok,mic print this.But why?? return 0 ; }
$icpc -V
//14.0
$icpc head.cpp main.cpp -o main
$./main
//I'm cpu
//I'm monkey
__________________________________________________________________________________
but why class point member fucntion f1 can not print out "I'm mic" ??
this is an interesting topic, isn't it? ^.^
thank u !
Hope that helps.
It does work well.
thanks very much.
void point::f1() { #pragma offload target(mic:0) { #ifdef __MIC__ for(int i = 0; i < 20; i++) { // Add this missing curly brace to for loop printf("I'm mic\n"); fflush(0); } #else //} // this curly brace is mis-placed - it should appear after the #endif below printf("I'm CPU\n"); #endif } // place curly brace here to enclose ifdef block in offload construct }With those changes the program runs as expected. Also, just a note, the __declspec(target(mic:0)) syntax does not include the target id, so this only needs to be: __declspec(target(mic)) For more info, see: Placing Variables and Functions on the Coprocessor
Hope that helps.
Great. You're welcome.
after reading these information, we get this conclusion:
"Do not use the __MIC__
macro inside the statement following a #pragma offload
statement."
thanks your link, it's really useful !
Hope that helps.
