Software Archive
Read-only legacy content
MPI startup fail
VIKRANT_G_
hello
I am running a MPI program which involves 5 ranks communicating with each other. The program runs fine when i run it on Xeon platform but when i put one of the process rank on MIC the program crashes giving me a segmentation fault
mpi version: intel Mpi, 4.1.1.036
This is how i am setting up the libraries and compiler settings for mic
export LD_LIBRARY_PATH=/opt/intel/composerxe/lib/mic:$LD_LIBRARY_PATH
export I_MPI_MIC=1
scp /opt/intel/impi/4.1.1.036/mic/bin/pmi_proxy mic0:/bin
scp /opt/intel/impi/4.1.1.036/mic/lib/* mic0:/lib64/.
and then i use the below run command:-
mpirun -genv I_MPI_DEBUG 5 -host localhost -n 1 FILE1 : -host mic0 -n 1 ~/FILE2 : -host localhost -n 1 FILE3 : -host localhost -n 1 FILE4: -host localhost -n 1 FILE5
This is the error/ MPI debug message i get
[0] MPI startup(): cannot open dynamic library libdat2.so.2
[4] MPI startup(): cannot open dynamic library libdat2.so.2
[2] MPI startup(): cannot open dynamic library libdat2.so.2
[3] MPI startup(): cannot open dynamic library libdat2.so.2
[0] MPI startup(): cannot open dynamic library libdat.so.1
[4] MPI startup(): cannot open dynamic library libdat.so.1
[2] MPI startup(): cannot open dynamic library libdat.so.1
[3] MPI startup(): cannot open dynamic library libdat.so.1
[4] ERROR - load_iblibrary(): Can't open IB verbs library: libibverbs.so: cannot open shared object file: No such file or directory
[2] ERROR - load_iblibrary(): Can't open IB verbs library: libibverbs.so: cannot open shared object file: No such file or directory
[0] ERROR - load_iblibrary(): Can't open IB verbs library: libibverbs.so: cannot open shared object file: No such file or directory
[3] ERROR - load_iblibrary(): Can't open IB verbs library: libibverbs.so: cannot open shared object file: No such file or directory
[1] MPI startup(): cannot open dynamic library libdat2.so.2
[1] MPI startup(): cannot open dynamic library libdat.so.1
[1] ERROR - load_iblibrary(): Can't open IB verbs library: libibverbs.so: cannot open shared object file: No such file or directory
[3] MPI startup(): shm and tcp data transfer modes
[4] MPI startup(): shm and tcp data transfer modes
[2] MPI startup(): shm and tcp data transfer modes
[0] MPI startup(): shm and tcp data transfer modes
[1] MPI startup(): shm and tcp data transfer modes
Sumedh_N_Intel
Have you transferred the listed library files (libdat.so, libdat2.so.2, ... )  to coprocessor?  Also, I think you will need to set the LD_LIBRARY_PATH on the coprocessor to point to these files.
Loc_N_Intel
Hi Vikrant,
Just curious, have you tried to download and run your MPI program directly in mic0 instead from host?
VIKRANT_G_
hi Ioc-nguyen and Sumedh,
thanks for the inputs
The program runs fine now, the error was due to the code itself, I changed the rank of the processes in the mpirun command but did not update it in the mpi_send and mpi_recv command
