Software Archive
Read-only legacy content
MPSS 3.8.4 modules for CentOS 7.5
JJK
Neuer Beitragender III
923Aufrufe
Hi all,
I've created an RPM and SRPM of the mpss 3.8.4 mpss-modules file to allow you to use your KNC Xeon Phi's on CentOS 7.5. The resulting files can be found here:
https://www.nikhef.nl/~janjust/mpss
or simply install the RPM using
rpm -Uvh https://www.nikhef.nl/~janjust/mpss/mpss-modules-3.10.0-862.el7.x86_64-3.8.4-1.x86_64.rpm
This works fine on my CentOS 7.5 box, but of course, use at your own risk and rattle your local Intel rep for an official update.
share and enjoy,
JJK
2 Antworten
phi__jack
Anfänger
923Aufrufe
Hi JJK,
I jave installed centos 7.5 and mpss 3.8.4 and applied your rpm but it couldn't use the card and i have some error like this "Region 0: Memory at (64-bit, prefetchable)[disabled]".
Are doing some patchs to the kernel before?
JJK
923Aufrufe
I'm only seeingthis post now, sorry about that...
The error you are seeing seems related to the infamous "Above 4 GB encoding" setting in your BIOS -f if the kernel does cannot find the memory space for the MIC card it will never boot, no matter what version of the OS. Or did it work with CentOS 7.4 , and did it stop working with 7.5 ?
Antworten
