Software Archive
Read-only legacy content
Making sure of legal license usage
Simone_A_1
In 2013 I have bought an license for the Intel Visual Fortran Composer XE 2013. I do not need and have never used the support or update possibilities (exept from this one I suppose).
I would like to know, whether the simple use of the Fortran Compiler is legal use of the license from 2013 or if I should have had an license renewal. For my company it is very important to use only legal licenses. Therefore I would appreciate your answer. Many thanks.
Simone
Hubert_H_Intel
Simone,
With the purchase of your license you have also the right of unlimited usage of the product. Support refers to technical support via the Intel® Premier Support and product updates only. With a new product purchase you have 1 year of support included and if you want to contue to get support you need to purchase a support service renewal.
Does this help?
Regards, Hubert.
Simone_A_1
Thank you very much. That did help indeed.
Follow-up question: I installed Intel Visual Fortran Composer XE 2013 on a new laptop (substitute for the old one), but when I want to activate this installation I get the message that the license / support is expired. Which is true, but I just want to reinstall the product on a new machine and continue to use it in the same way as before. Is there any chance I can activate the composer?
Simone
Hubert_H_Intel
Simone,
Remote services are not supported for expired licenses, so you need to use the license file to install the product. I sent you the license file of your latest registration.
Hubert.
