Software Archive
Read-only legacy content
17060 Discussions
Mounting over NFS with MPSS 3.4.1
Alastair_M_
Dear all,
I must apologise for this seemingly simple question.
I am having a problem mounting anything over nfs since I installed a new MIC card and installed MPSS 3.4.1.  I have a working NFS setup on another machine with MPSS 3.2.1 but the same script is not working for me with my new MIC.
I am using micctrl like this:
sudo micctrl --addnfs=172.31.1.254:/micnfs/ --dir=/micnfs
I then ran:
sudo service mpss stop
sudo micctrl --resetconfig
sudo service mpss start
When I ssh into the MIC, the /micnfs is not mounted and the /etc/fstab looks like this:
[root@cluster1-mic0 ~]# cat /etc/fstab
rootfs        /        auto        defaults        1  1
proc        /proc        proc        defaults        0  0
devpts        /dev/pts    devpts        mode=0620,gid=5        0  0
Should the micctrl with addnfs not add this the mount point to /etc/fstab?
Looking at the cotents of /var/mpss/mic0/etc/fstab shows the same default values as shown above.
Did I miss a crucial step here?  I read the steps from the document here: http://registrationcenter.intel.com/irc_nas/4862/mpss_users_guide.pdf
Are these instructions still correct?
Alastair
Frances_R_Intel
Skip the 'micctrl --resetconfig'. The next release of the User's Guide is removing a number of references to using the resetconfig option and in this case, you should omit that step. The original purpose of 'micctrl --resetconfig' was to push changes from the micN.conf file out into the "real" configuration files. This was before you used micctrl to change the configuration files directly.
Frances_R_Intel
Alastair_M_
Thanks Frances, that worked perfectly.  Do you know when the up to date user guide might be ready?
Alastair
TaylorIoTKidd
Alastair,
The new User Guide is in the works and is estimated for early next year. but we don't have an estimate for it's release at this time.
Taylor
Alastair_M_
Taylor Kidd (Intel) wrote:
Alastair,
Taylor
Thanks Taylor.  On a slightly related question, is there a mailing list for subscribing to MPSS/documentation updates?
Alastair
Frances_R_Intel
When a new MPSS is released, it is added to the downloads page and is announced in this forum. You can subscribe to follow the downloads page https://software.intel.com/en-us/articles/intel-manycore-platform-software-stack-mpss or, if you don't mind the traffic, you can subscribe to follow this forum https://software.intel.com/en-us/forums/intel-many-integrated-core.
