Dear all,
I must apologise for this seemingly simple question.
I am having a problem mounting anything over nfs since I installed a new MIC card and installed MPSS 3.4.1. I have a working NFS setup on another machine with MPSS 3.2.1 but the same script is not working for me with my new MIC.
I am using micctrl like this:
sudo micctrl --addnfs=172.31.1.254:/micnfs/ --dir=/micnfs
I then ran:
sudo service mpss stop sudo micctrl --resetconfig sudo service mpss start
When I ssh into the MIC, the /micnfs is not mounted and the /etc/fstab looks like this:
[root@cluster1-mic0 ~]# cat /etc/fstab
rootfs / auto defaults 1 1
proc /proc proc defaults 0 0
devpts /dev/pts devpts mode=0620,gid=5 0 0
Should the micctrl with addnfs not add this the mount point to /etc/fstab?
Looking at the cotents of /var/mpss/mic0/etc/fstab shows the same default values as shown above.
Did I miss a crucial step here? I read the steps from the document here: http://registrationcenter.intel.com/irc_nas/4862/mpss_users_guide.pdf
Are these instructions still correct?
Alastair
Skip the 'micctrl --resetconfig'. The next release of the User's Guide is removing a number of references to using the resetconfig option and in this case, you should omit that step. The original purpose of 'micctrl --resetconfig' was to push changes from the micN.conf file out into the "real" configuration files. This was before you used micctrl to change the configuration files directly.
Thanks Frances, that worked perfectly. Do you know when the up to date user guide might be ready?
Alastair
Alastair,
The new User Guide is in the works and is estimated for early next year. but we don't have an estimate for it's release at this time.
Taylor
Taylor Kidd (Intel) wrote:
Alastair,
but we don't have an estimate for it's release at this time.Regards
Taylor
Thanks Taylor. On a slightly related question, is there a mailing list for subscribing to MPSS/documentation updates?
Alastair
When a new MPSS is released, it is added to the downloads page and is announced in this forum. You can subscribe to follow the downloads page https://software.intel.com/en-us/articles/intel-manycore-platform-software-stack-mpss or, if you don't mind the traffic, you can subscribe to follow this forum https://software.intel.com/en-us/forums/intel-many-integrated-core.
