Software Archive
Read-only legacy content
17060 Discussions
[OMX.Intel.VideoEncoder.AVC] Problem with Vuzix M300, cannot encode H264
Drira__Ahmed
Hello Everyone,
I am developing a Streaming app on the Vuzix M300 (Smart Glasses), using Wowza Streaming Engine, I tested it on other ARM android devices and it works perfectly, and I found out that the Vuzix Runs with intel Architecture.
The issue is that, when I start the streaming, I get this error in the logs :
11-21 08:46:48.241 6441-6614/com.example.vid  I/OMXClient: Using client-side OMX mux.
11-21 08:46:48.252 6441-6614/com.example.vid E/ACodec: [OMX.Intel.VideoEncoder.AVC] storeMetaDataInBuffers (output) failed w/ err -2147483648
11-21 08:46:48.252 6441-6614/com.example.vid  W/ACodec: do not know color format 0x7f000789 = 2130708361
11-21 08:46:48.255 6441-6614/com.example.vid  W/ACodec: Use baseline profile instead of 8 for AVC recording
The streaming works for H263 incoming streams but not for H264 ones.
Any suggestions on what might be the cause of this issue ? is it a problem with the wowza SDK I'm using that does not get along with the intel Media Codecs ?
Any help is appreciated, Thank you :)
Quoc-Thai_L_Intel
You might want to check with the Intel(R) XDK forum on this topic. They may have some input for you there.  Here is the URL:https://software.intel.com/en-us/forums/intel-xdk
-Thai
