Software Archive
Read-only legacy content
17060 Discussions
Offload program with STL vector
H__Kamil
I've got a problem with my program. It's simple code which show my problem.
#pragma offload_attribute (push, target(mic))
#include <vector>
#include "offload.h"
#include <stdio.h>
#pragma offload_attribute (pop)
class A
	public:
	A() {}
	std::vector<int> V;
int main()
	A* wsk = new A();
	wsk->V.push_back(1);
	#pragma offload target(mic) in(wsk)
		printf("%d", wsk->V[0]);
		printf("END OFFLOAD");
	return 0;
I've got a class object with STL vector which is container for data needed to computation. I would like to create object on host, initialize data for computation on host too, then i want to move class object to do computation on Intel Xeon Phi coprocessor. In result i got error:
offload error: process on the device 0 was terminated by signal 11 (SIGSEGV)
Why it doesn't work correctly? How to transfer STL vector to coprocessor?
Frances_R_Intel
When the data you want to pass between the host and the coprocessor is not bit-wise copyable, as in this case, you need to use the virtual shared memory offload model. Check out the sample code that comes with the compilers (which installs in /opt/intel/composerxe/Samples/en_US/C++/mic_samples/shrd_sampleCPP by default) and the section on shared memory programming in the C++ User's Guide in the Intel® Software Documentation Library (https://software.intel.com/en-us/node/522494 for the 15.0 version of the compiler.)
