I am trying to open a pdf document from a html link in intel xdk.
I am trying to do this by opening the pdf in a modal with an iframe element in it. Unfortunately that isn't working the phones.
<div class="modal outer-element uib_w_20" data-uib="twitter%20bootstrap/modal" data-ver="1" data-backdrop="true" id="popShowHref"> <div class="modal-dialog"> <div class="modal-content"> <div class="modal-header"> <button class="close" data-dismiss="modal">x</button> <h4 class="modal-title"> <span><i class="glyphicon glyphicon-cog"></i> Notice</span> </h4> </div> <div class="modal-body"> <div class="col uib_col_12 single-col" data-uib="layout/col" data-ver="0"> <div class="widget-container content-area vertical-col"> <form> <iframe height="200" width="200" src="http://www.ccs.neu.edu/home/riccardo/courses/cs6750-fa09/talks/Ellis-elliptic-curve-crypto.pdf"></iframe> </form> <!--<span class="uib_shim"></span>--> </div> </div> </div> <div class="modal-footer"></div> </div> </div> </div>
The above code isn't working. When I am opening this in XDK emulator, its asking me to download the pdf, but when I am opening this in phone, I do not get any option and the iframe remains blank!
Any solution to this problem ?
- Tags:
- HTML5
- Intel® XDK
You should use the In App Browser plugin provided in the XDK instead of iframe.
Some URLs do not render in iFrame due to security issues. You best bet is the InAppBrowser plugin. Here is the link to its documentation: http://docs.phonegap.com/en/edge/cordova_inappbrowser_inappbrowser.md.html
For example, if you want to display the webpage in the click of a button, this is all you have to do:
$(document).on("click", ".uib_w_3", function(evt)
/* your code goes here */
var ref = window.open('https://software.intel.com/en-us/xdk/articles/android-splash-screens-usi...', '_blank', 'location=yes');
![](/skins/images/98E68944C1FF703B8AC50091329B92AF/responsive_peak/images/icon_anonymous_message.png)
