Software Archive
Read-only legacy content
17061 Discussions
OpenCV and Galileo Gen1
Anonymous
Not applicable
I have read many questions over the last few months but I cannot find a tutorial for what I need and I am pretty lost to be honest. Can anyone help out in guiding me to complete my goal for one of my systems.
I have a system built on an Intel Galileo Gen 1 and I want to be able to provide a feature that from the GUI I have built for the system, users can view a stream from the webcam attached to the board to see realtime what is going on in the location surrounding the unit. I have searched and searched, seen all of the videos on google and still can't find a kind of step by step from installing opencv to getting it running so I can connect to the webcam that is attached to the board.
If anyone can help will be appreciated.
Anonymous
Not applicable
Hi matthias-hahn (Intel) / Stewart Christie (Intel)
BOOM :D Ok got it taking a photo.
#include <opencv2/opencv.hpp>
using namespace cv;
using namespace std;
int main()
VideoCapture cap(-1);
//check if the file was opened properly
if(!cap.isOpened())
cout << "Webcam could not be opened succesfully" << endl;
exit(-1);
else
cout << "p n" << endl;
int w = 960;
int h = 544;
cap.set(CV_CAP_PROP_FRAME_WIDTH, w);
cap.set(CV_CAP_PROP_FRAME_HEIGHT, h);
Mat frame;
cap >>frame;
imwrite("opencv.jpg", frame);
cap.release();
return 0;
 Stewart Christie (Intel) Thank you the ebook got me here. So my next stage is to make the node js server trigger this file and save an image that can be accessed via the node server is this possible ? Once I have that sorted I will look into the video streaming but this is definitely a move forward thanks for help so far :D
samontab
Valued Contributor II
I wrote a very detailed tutorial for installing OpenCV for Ubuntu 14.04. You may be able to use it as a reference to install it on Galileo:
http://www.samontab.com/web/2014/06/installing-opencv-2-4-9-in-ubuntu-14-04-lts/
Anonymous
Not applicable
Hi thanks for the reply am I wrong in thinking that it is already part of the IoT dev kit image ? Do you have any info for getting the dev kit installation working and running a script that will allow me to stream the video to the GUI ?
Matthias_H_Intel
No, you are right: if you use the Intel(R) IoT devkit SD card image (eglibc based) OpenCV will be part of. And you should find quite a number of examples online - e.g. http://docs.opencv.org/modules/highgui/doc/reading_and_writing_images_and_video.html.
I'd suggest starting with
  • capture a frame and write to a file - if that works you know you can access the camera fine
Anonymous
Not applicable
Hi thanks for the post I have been going for months trying to find anything that works. The closest I have got is:#
#include "opencv2/highgui/highgui.hpp"
#include <iostream>
using namespace cv;
int main(int argc, char* argv[])
    VideoCapture cap(0); // open the video camera no. 0
    if (!cap.isOpened())  // if not success, exit program
        cout << "Cannot open the video cam" << endl;
        return -1;
    } else {
        cout << "OPened Cam" << endl;
   double dWidth = cap.get(CV_CAP_PROP_FRAME_WIDTH); //get the width of frames of the video
   double dHeight = cap.get(CV_CAP_PROP_FRAME_HEIGHT); //get the height of frames of the video
    cout << "Frame size : " << dWidth << " x " << dHeight << endl;
    namedWindow("MyVideo",CV_WINDOW_AUTOSIZE); //create a window called "MyVideo"
    //VideoWriter video("capture.avi",CV_FOURCC('M', 'J', 'P', 'G'), 10, cvSize((int)dWidth,(int)dHeight) );
    cout << "GOT HERE" << endl;
    while (1)
        Mat frame;
        bool bSuccess = cap.read(frame); // read a new frame from video
         if (!bSuccess) //if not success, break loop
             cout << "Cannot read a frame from video stream" << endl;
             break;
        imshow("MyVideo", frame); //show the frame in "MyVideo" window
        if (waitKey(30) == 27) //wait for 'esc' key press for 30ms. If 'esc' key is pressed, break loop
            cout << "esc key is pressed by user" << endl;
            break;
    return 0;
Which returns:
root@quark00a8ee:~# chmod 755 /tmp/TASS;/tmp/TASS ;exit
VIDIOC_QUERYMENU: Invalid argument
OPened Cam
Frame size : 640 x 480
(MyVideo:353): Gtk-WARNING **: cannot open display:
logout
I am using Intel Gen 1, IoT dev kit and Logitech HD720p using Eclipse IoT IDE
Matthias_H_Intel
some hints:
  • find out (e.g. debugger) where "VIDIOC_QUERYMENU: Invalid argument" is print out if this message is relevant
  • apparently your camera got openened fine (I suppose 640x480 resolution is fine? possibly you'd have to change the resolution via V4L to allow higher fps on Galileo)
  • I'd recommend to start writing frames to files rather than to use imshow
 Once you get correct frames start checking your X setup for your attached display. You would at least need to run something like X11 or Wayland - possibly also a display manager. Apparently it's not yet correctly set ("cannot open display").
Matthias_H_Intel
just saw you tried VideoWriter - did that work?
Anonymous
Not applicable
Sorry you totally lost me with most of what you said above. I mentioned I have been banging my head with this for a while and I cannot get my head around what is going wrong.
VideoWriter gives
VIDIOC_DQBUF: No such device
(MyVideo:380): Gtk-WARNING **: cannot open display:
So I guess not, how come there is no tutorial for this yet, pretty much every topic I have found on it no one ever provides an answer and its always the same errors. Totally stumped on how to get it working.
Debug just says:
root@quark00a8ee:~# chmod 755 /tmp/TASS;gdbserver :2345 /tmp/TASS;exit
Process /tmp/TASS created; pid = 397
Listening on port 2345
Remote debugging from host PC IP
Anonymous
Not applicable
#include <vector>
#include <stdio.h>
using namespace cv;
void createAlphaMat(Mat &mat)
    for (int i = 0; i < mat.rows; ++i) {
        for (int j = 0; j < mat.cols; ++j) {
            Vec4b& rgba = mat.at<Vec4b>(i, j);
            rgba[0] = UCHAR_MAX;
            rgba[1] = saturate_cast<uchar>((float (mat.cols - j)) / ((float)mat.cols) * UCHAR_MAX);
            rgba[2] = saturate_cast<uchar>((float (mat.rows - i)) / ((float)mat.rows) * UCHAR_MAX);
            rgba[3] = saturate_cast<uchar>(0.5 * (rgba[1] + rgba[2]));
int main(int argv, char **argc)
    // Create mat with alpha channel
    Mat mat(480, 640, CV_8UC4);
    createAlphaMat(mat);
    vector<int> compression_params;
    compression_params.push_back(CV_IMWRITE_PNG_COMPRESSION);
    compression_params.push_back(9);
        imwrite("alpha.png", mat, compression_params);
    fprintf(stdout, "Saved PNG file with alpha data.\n");
    return 0;
Well this worked kind of.
Anonymous
Not applicable
So I have managed to write an image but it is blank :S
The camera light is coming on until script ends so making progress, any ideas to push this one forward anyone ?
#include "opencv2/opencv.hpp"
#include <iostream>
using namespace cv;
int main(int, char**)
        return -1;
    } else {
        cout << "Opened Cam" << endl;
	Mat save_img; cap >> save_img;
	if(save_img.empty())
		cout << "Something is wrong with the webcam, could not get frame." << endl;
	} else {
		cout << "Writing Image." << endl;
		imwrite("test.jpg", save_img); // A JPG FILE IS BEING SAVED
		cout << "Written Image test.jpg" << endl;
	return 0;
Opened Cam
select timeout
Writing Image.
logout
Anonymous
Not applicable
OK last update need to sleep lol.
#include <iostream>
using namespace cv;
int main(int, char**){
    if (!cap.isOpened()){
        return -1;
    } else {
	Mat frame; cap >> frame;
	if (!bSuccess){
		return -1;
	} else {
		cout << "Read a frame from video stream" << endl;
	cout << "Writing Image" << endl;
	imwrite("bleh.png", frame);
	cout << "Image Written " << endl;
	return 0;
Gives me:
Opened Cam
select timeout
select timeout
Writing Image
Image Written
logout
And black image still
Matthias_H_Intel
#include <iostream>
using namespace cv;
        return -1;
    } else {
	} else {
	return 0;
Opened Cam
select timeout
Writing Image.
logout
false
code looks ok - maybe try specifying the camera in VideoCapture (e.g. set to '0' = default, or to '1', ..., '99'). Maybe you're on a "/dev/zero" kind of camera?
You could write a quick OpenCV program to scan through the cameras to get a list of existing ones
Matthias_H_Intel
at this stage you could also work on e.g. a Windows, or a Linux host (I am pretty sure OSX would work the same but I never tried OpenCV there). and compare results with what you get on Galileo
Stewart_C_Intel
There's a great book published by Apress, and the ebook is free http://www.apress.com/9781430268390 and it has gen 1 and gen 2 OpenCV examples for both C++ and Python, even includes the different frame rates. Example code and a tutorial is difficult to beat.
The Kindle version is free too.
Anonymous
Not applicable
Hi thanks I have downloaded it will check it out, have you any idea why the image is black ?
Anonymous
Not applicable
using namespace cv;
int main()
if(!cap.isOpened())
exit(-1);
else
int w = 960;
int h = 544;
Mat frame;
cap >>frame;
cap.release();
return 0;
Anonymous
Not applicable
Now that is sorted I think I will leave the c++ for when  I integrate my AI, looking at https://github.com/peterbraden/node-opencv now as I think it will be better suited for what I want to do. For anyone else that was worried about the following errors:
I found that these are actually standard and not an error that effects the code, I am not 100% sure but I think the reason the image was black for me was because I was creating a PNG, looking at my previous code and the functioning code it is pretty much all I can see different so maybe this was the reason.
Also Stewart Christie (Intel) thanks again for the eBook its pretty cool and will check it out in more detail soon.
Matthias_H_Intel
good you were able to proceed - btw: I already asked you earlier whether the image dimensions are correct ;-) "I suppose 640x480 resolution is fine"
Anonymous
Not applicable
Could you give me some feedback on my project ? This is the project link on my website, I have to update some info and the videos but you can see the GUI I have built etc. If you like would be great if you could use the social buttons on the page :D
https://www.techbubble.info/internet-of-things/tass-techbubble-assisted-security-system
Anonymous
Not applicable
Well issues with node-opencv now lol won't install :S What ways are there to have to the node server trigger the c++ function on demand, the effect I am trying to get is:
if motion, light or sound detected > trigger the camera recording > send file name with the request that updates the database and then at a later date the user can view those images. The only other thing I can think of at the moment is just have it permanently running in a loop but this will fill up the storage in no time. Any suggestions.
Matthias_H_Intel
what are the issues with "install"?
circular buffer?
