Software Archive
Read-only legacy content
PCI-X DMA on Xeon systems -- cache problem?
schellho
We are attempting to perform 64B burst PCI-X DMA write transfers from our add-in card into host memory on a dual Xeon system.
Our linux device driver (kernel 2.24.x/2.26.x) is notified via an interrupt & single dword "doorbell" write that the larger 64B entry is available for processing.
The order of operation on the PCI-X bus is as follows:
64B data write --> 4B doorbell write --> interrupt.
Upon receiving the interrupt, the device driver polls the location in memory where the 4B doorbell write is expected to show up. Once he sees the doorbell location written, he reads the 64B data location. PCI ordering should guarantee that the 64B data location is written to system memory before the 4B doorbell write is.
The above writes are performed as Memory Write Block transactions (we have also tried Memory Write transactions), the No Snoop bit is cleared, and the Relaxed Ordering bit is cleared.
We consistently encounter a situation where the device driver correctly receives the interrupt & single dword doorbell write, but the 64B write fails to appear in memory. Instead, the device driver reads a stale 64B block of data (data from the last successful DMA write).
As a debug measure, we had the FPGA on our add-in card perform a readback (Memory Read Block) of the 64B entry immediately after writing it. We obeserved that the data read back was stale and matched the stale data that the device driver saw. Eg:
1) Location 0xABCDEF00 is known to contain stale 64B data 0xAAAA....AAAA.
1) FPGA does Memory Write Block 64B 0xBBBB....BBBB at address 0xABCDEF00.
2) FPGA does Memory Read Block 64B at address 0xABCDEF00 (Split esponse).
3) Split Completion is returned by bridge with data 0xAAAA....AAAA.
This appears to be a violation of PCI ordering rules. Again, the No Snoop and Relaxed Order bits are cleared for all of these transactions.
The device driver *never* writes to the 64B location, so there should be no possibility of a collision occurring where he writes/flushes stale data that overwrites the incoming DMA write.
This tells me that the location is NOT getting written because, according to PCI ordering rules, the FPGA read *must* push the Memory Write Block into system memory before reading back the location.
We observe this behaviour in dual Xeon systems with both the Intel E7501 chipset and the Broadcom Serverworks GC-LE chipset.
We observe this in SMP and single processor configurations.
When bus traffic is light at 133MHz, or whenever the bus is running at 66MHz, we do *not* observe this problem. We occasionally observe the problem when the bus is running at 100MHz with heavy traffic. This suggests that we are hitting a narrow timing window at higher bus speeds.
We are suspicious that we might be encountering a cache errata in the Xeon, and are wondering if anyone can confirm this and possibly provide a workaround?
Intel_Software_Netw1
This is somewhat outside the scope of what our group supports, but we will forward this issue to our engineering contacts in the Intel Server Products group for investigation.
Lexi S.
IntelSoftware NetworkSupport
http://www.intel.com/software
Contact us
Message Edited by intel.software.network.support on 12-01-2005 07:01 PM
Our hardware support contacts responded that this inquiry will require a closer look by an Intel Product Representative.
If your company has its own Intel representative, you may wish to inquire whether they are able to assist with this inquiry. Your company's Purchasing Department will normally have your Intel representative's contact information. If you have no contact, please see http://www.intel.com/buy/wtb/wtb1023.htm under "Design Help".
If your location is not listed, please see an Intel Authorized Distributor and ask for a Field Application Engineer (FAE). Our Intel Authorized Distributor list is also linked from the URL above.
Lexi S.
Contact us
kirick
I am having difficulty performing DMA transactions with an FPGA based PCI Express device using the Intel E7525 Chipset. I was wondering if you were able to get your problem resolved? If you did, can you forward an email of the person that assisted you so that I may ask my question. Thanks.
Your design inquiry will require a closer look by an Intel Product Representative.
Jim A.
Contact us
rshal2
New Contributor II
I have the same issue,
Why we can't do DMA and access RAM from PCIe only with Xeon chips?
Please help,
Ran
