Software Archive
Read-only legacy content
17060 Discussions
Parallel Studio 2016 error: (This platform not authorized by license (-89,337))
mirsepassi__sosh
We downloaded the new Parallel Studio 2016 and our new license file and installed the product and updated the license server to use the upgraded file but we get a license error:
License check failed
    Fri 23 Oct 2015 04:26:44 PM PDT  Intel VTune Amplifier XE 2016 cannot find valid license. Data cannot be displayed.
Error 0x4000001f (No valid license) -- The license is unavailable. Make sure that your license file contains the license for the requested feature. If your license requires a license server, make sure that the server is using the right license file, and you have not changed the license file since starting the server.
If we look at the license server log we see errors like this:
 9:54:11 (INTEL) DENIED: "IF83F2F10" xyz@foo??.bar??.com  (This platform not authorized by license (-89,337))
How can we fix this issue?
Sosh
Kenneth_C_Intel
Hi I am going to send you a private message to help you with this.
Kenneth
Intel Developer Support
Jeeho_L_
I can't upgrade from Parallel studio xe fortran for OS X 2015 to 2016. During installation i got the following message:
Last login: Wed Oct 28 21:50:05 on ttys000
SingularDozen:~ leejeeho$ /Applications/m_fcompxe_online_2016.0.033.app/Contents/Resources/online-installer.sh ; exit;
Welcome to the online installer for Intel(R) Parallel Studio XE 2016 Composer Edition for Fortran OS X*.
Before proceeding, the installer will check few prerequisites...
 - Checking for 'awk'... [success]
 - Checking for 'tar'... [success]
 - Checking for 'cksum'... [success]
Checking Intel(R) Software Development Products Registration Center availability... [success]
Temporary files will be downloaded to:/var/folders/cx/4k35r7993c97gtjhl5k7jkgw0000gn/T//leejeeho/m_fcompxe_2016.0.033
Downloading the package content file, this might take several minutes...
######################################################################## 100.0%
 [success]
Downloading the installer for Intel(R) 64 architecture, this might take several minutes...
 [success]
./install.sh: line 616:  1512 Segmentation fault: 11  "$pset_engine_binary" --TEMP_FOLDER="$temp_folder" $params $root_nonroot 2> /dev/null
logout
Devorah_H_Intel
This is a known issue and it is being fixed in Update 1. Unfortunately, there is no workaround other than waiting for the update. We apologize for the delay and appreciate your patience with this.
Light_Intel
This is a known issue and is being addressed. If you have a similar issue, do not add it to this thread but start a new one.
Shay_B_
I have the same issue with ThreadAnlGui  2016...
Any fix?
Devorah_H_Intel
Any fix?
Update 1 is available for download from Intel Registration Center. The fix for the original issue is included in Update 1. Please let me know if you need help.
