This is not installing on W7 SP1. "Install" immediately goes to "Complete", bypassing the "Installation" step, without installing anything, no error messages or indications of any kind as to what the problem is. Please help.
- Tags:
- Development Tools
- Intel® License Manager for FLEXlm*
- Intel® Software Development Products Registration Center
It llooks like you have a wrong license or a license file on your system that is not for installing the Intel® Parallel Studio XE 2015 Professional Edition. Could you please let me know your serial number (please anser via "Send Author A Message").
Regards, Hubert.
Ok, assuming you installed already other licenses on this machine (otherwise the error description wouldn't make sense), please remove all license files (.lic) you can find on your system under the paths
c:\Program Files (x86)\Common Files\Intel\
c:\Program Files (x86)\Intel\
or if it's a 32-bit Windows under:
c:\Program Files\Common Files\Intel\
c:\Program Files\Intel\
It may also be helpful if you renamed the default license path
c:\Program Files (x86)\Common Files\Intel\Licenses / c:\Program Files\Common Files\Intel\Licenses
for the time of installation so that the installer can create the license entry from scratch.
Another idea is to use the license file ('Alternative activation options .... Use license file'). I sent the license file to your email.
I hope this helps.
Hubert.
