Software Archive
Read-only legacy content
17061 ディスカッション
Performance Evaluations in VMWare Workstation 12 Player
SergeyKostrov
高評価コントリビューター II
1,499件の閲覧回数
*** Performance Evaluations in VMWare Workstation 12 Player ***
0 件の賞賛
10 返答(返信)
SergeyKostrov
高評価コントリビューター II
1,499件の閲覧回数
[ Abstract ] Virtualization software, like WMware Player or Oracle VM Virtual Box, improves productivity and capabilities of software engineers by virtualizing some Operating System ( Guest OS ) inside another Operating System ( Host OS ). Virtualization software allows to reuse hardware to run several OSs at the same time. However, performance of processing is affected and results of testing clearly demonstrate it.
SergeyKostrov
高評価コントリビューター II
1,499件の閲覧回数
[ Linux Ubuntu 16.04 LTS in VMware Player Workstation 12 on Dell Precision Mobile Workstation ] Intel Core i7-3840QM ( 2.80 GHz / Ivy Bridge / 4 cores ) Processor : Intel Core i7-3840QM Cores : 4 Processors ( CPUs ): 8 http://ark.intel.com/products/70846 Windows 7 SP1 is a Host OS. Linux Ubuntu 16.04 LTS is a Guest OS.
SergeyKostrov
高評価コントリビューター II
1,499件の閲覧回数
[ Linux Ubuntu on IVB virtualized Test 1 ] ... ubuntu@ubuntu-vm:~/WorkEnvMIC$ ./hpctest1.out Starting Compute GFlops = 25.600, Secs = 4.039, GFlops per sec = 6.338 ... [ Linux Ubuntu on IVB virtualized Test 2 ] ... ubuntu@ubuntu-vm:~/WorkEnvMIC$ ./hpctest2.out Starting Compute on 2 threads GFlops = 51.200, Secs = 6.626, GFlops per sec = 7.727 ... [ Linux Ubuntu on IVB virtualized Test 3 ] ... ubuntu@ubuntu-vm:~/WorkEnvMIC$ ./hpctest3.out Starting Compute on 4 threads GFlops = 204.800, Secs = 14.818, GFlops per sec = 13.821
SergeyKostrov
高評価コントリビューター II
1,499件の閲覧回数
[ Windows 7 on IVB real Test 1 ] ... ..\WorkEnvMIC>hpctest1.exe Starting Compute GFlops = 25.600, Secs = 3.233, GFlops per sec = 7.918 ... [ Windows 7 on IVB real Test 2 ] ... ..\WorkEnvMIC>hpctest2.exe Starting Compute on 2 threads GFlops = 51.200, Secs = 4.830, GFlops per sec = 10.600 ... [ Windows 7 on IVB real Test 3 ] ... ..\WorkEnvMIC>hpctest3.exe Starting Compute on 4 threads GFlops = 102.400, Secs = 6.365, GFlops per sec = 16.087 ...
SergeyKostrov
高評価コントリビューター II
1,499件の閲覧回数
[ Summary ] Performance is affected when some processing is done in a virtualized environment: Test 1 is ~1.26x slower ( 7.918 / 6.338 ) Test 2 is ~1.37x slower ( 10.600 / 7.727 ) Test 3 is ~1.16x slower ( 16.087 / 13.821 )
gaston-hillar
高評価コントリビューター I
1,499件の閲覧回数
Sergey,
Thanks for sharing this information. Can you share the test you are running? I mean, is it open source code?
SergeyKostrov
高評価コントリビューター II
1,499件の閲覧回数
>>...Can you share the test you are running?.. Please use STREAM benchmark if you would like to evaluate performance of your system(s).
gaston-hillar
高評価コントリビューター I
1,499件の閲覧回数
@Sergey,
Thanks for sharing the test you are running.
SergeyKostrov
高評価コントリビューター II
1,499件の閲覧回数
I also recommend to read IDZ article Optimizing Memory Bandwidth in Knights Landing on Stream Triad at https://software.intel.com/en-us/articles/optimizing-memory-bandwidth-in-knights-landing-on-stream-triad
gaston-hillar
高評価コントリビューター I
1,499件の閲覧回数
Sergey,
Thanks for the article recommendation. I had missed this one on IDZ, and therefore, your linked allow me to know about it and read it. :)
返信
