Software Archive
Read-only legacy content
17060 Discussions
Performance Evaluations in VMWare Workstation 12 Player
SergeyKostrov
Valued Contributor II
*** Performance Evaluations in VMWare Workstation 12 Player ***
SergeyKostrov
[ Abstract ] Virtualization software, like WMware Player or Oracle VM Virtual Box, improves productivity and capabilities of software engineers by virtualizing some Operating System ( Guest OS ) inside another Operating System ( Host OS ). Virtualization software allows to reuse hardware to run several OSs at the same time. However, performance of processing is affected and results of testing clearly demonstrate it.
SergeyKostrov
[ Linux Ubuntu 16.04 LTS in VMware Player Workstation 12 on Dell Precision Mobile Workstation ] Intel Core i7-3840QM ( 2.80 GHz / Ivy Bridge / 4 cores ) Processor : Intel Core i7-3840QM Cores : 4 Processors ( CPUs ): 8 http://ark.intel.com/products/70846 Windows 7 SP1 is a Host OS. Linux Ubuntu 16.04 LTS is a Guest OS.
SergeyKostrov
[ Linux Ubuntu on IVB virtualized Test 1 ] ... ubuntu@ubuntu-vm:~/WorkEnvMIC$ ./hpctest1.out Starting Compute GFlops = 25.600, Secs = 4.039, GFlops per sec = 6.338 ... [ Linux Ubuntu on IVB virtualized Test 2 ] ... ubuntu@ubuntu-vm:~/WorkEnvMIC$ ./hpctest2.out Starting Compute on 2 threads GFlops = 51.200, Secs = 6.626, GFlops per sec = 7.727 ... [ Linux Ubuntu on IVB virtualized Test 3 ] ... ubuntu@ubuntu-vm:~/WorkEnvMIC$ ./hpctest3.out Starting Compute on 4 threads GFlops = 204.800, Secs = 14.818, GFlops per sec = 13.821
SergeyKostrov
[ Windows 7 on IVB real Test 1 ] ... ..\WorkEnvMIC>hpctest1.exe Starting Compute GFlops = 25.600, Secs = 3.233, GFlops per sec = 7.918 ... [ Windows 7 on IVB real Test 2 ] ... ..\WorkEnvMIC>hpctest2.exe Starting Compute on 2 threads GFlops = 51.200, Secs = 4.830, GFlops per sec = 10.600 ... [ Windows 7 on IVB real Test 3 ] ... ..\WorkEnvMIC>hpctest3.exe Starting Compute on 4 threads GFlops = 102.400, Secs = 6.365, GFlops per sec = 16.087 ...
SergeyKostrov
[ Summary ] Performance is affected when some processing is done in a virtualized environment: Test 1 is ~1.26x slower ( 7.918 / 6.338 ) Test 2 is ~1.37x slower ( 10.600 / 7.727 ) Test 3 is ~1.16x slower ( 16.087 / 13.821 )
gaston-hillar
Sergey,
Thanks for sharing this information. Can you share the test you are running? I mean, is it open source code?
SergeyKostrov
>>...Can you share the test you are running?.. Please use STREAM benchmark if you would like to evaluate performance of your system(s).
gaston-hillar
@Sergey,
Thanks for sharing the test you are running.
SergeyKostrov
I also recommend to read IDZ article Optimizing Memory Bandwidth in Knights Landing on Stream Triad at https://software.intel.com/en-us/articles/optimizing-memory-bandwidth-in-knights-landing-on-stream-triad
gaston-hillar
Sergey,
Thanks for the article recommendation. I had missed this one on IDZ, and therefore, your linked allow me to know about it and read it. :)
