Software Archive
Read-only legacy content
17061 Discussions
Performance degradation if loop count is not known at compile time
Luca_A_
I am creating a simple matrix multiplication procedure, operating on the Intel Xeon Phi architecture.
After many attempts with autovectorization, trying to get better performances, I had to use Intel Intrinsics.
Until now, the matrix size was given by a #define in the source code, but when I try to give it at run time, I have a huge performance degradation.
The source code is the following:
#include <stdio.h>
#include <stdlib.h>
#include <time.h>
#include <math.h>
#include <stddef.h>
#include <chrono>
#include <ctime>
#include <mmintrin.h>
#include <xmmintrin.h>  // SSE
#include <pmmintrin.h>  // SSE2
#include <emmintrin.h>  // SSE3
#include <immintrin.h>
#include <zmmintrin.h>
#define ALIGNMENT 64
#ifndef SIZE
#define SIZE 960
#endif
#define vZero(c) {(c) = _mm512_setzero_pd();}
#define start_time() \
	auto start = std::chrono::high_resolution_clock::now();
/** Shows the elapsed time. See start_time for usage*/
#define elapsed_time(STRING) \
	auto elapsed = std::chrono::high_resolution_clock::now() - start; \
	long long microseconds = std::chrono::duration_cast<std::chrono::microseconds>(elapsed).count(); \
	printf(#STRING":%lld\n", microseconds);
void recTranspose(double *__restrict__ a, double *__restrict__ aT, const int n, const int k, const int lda, const int ldat){
	if (n*k <= 128) {
		for(int i = 0; i < n; i++) {
			for(int j = 0; j < k; j++) {
				aT[j*ldat+i] = a[i*lda+j];
		//printf("Reached _|_");
		return;
	if(k > n) {
		recTranspose(a, aT, n, (k+1)/2, lda, ldat);
		recTranspose(&a[(k+1)/2], &aT[(k+1)/2*ldat], n, k-((k+1)/2), lda, ldat);
	} else {
		recTranspose(a, aT, (n+1)/2, k, lda, ldat);
		recTranspose(&a[(n+1)/2*lda], &aT[(n+1)/2], n- (n+1)/2, k, lda, ldat);
/** Calculates 8 cols and 30 rows of c.*/
inline void eightbythirty(double *__restrict__ a, double *__restrict__ b, double * __restrict__ c, const int size) {
	__m512d c0, c1, c2, c3, c4, c5, c6, c7, c8, c9;
	__m512d c10, c11, c12, c13, c14, c15, c16, c17, c18, c19;
	__m512d c20, c21, c22, c23, c24, c25, c26, c27, c28, c29;
	vZero(c0);	vZero(c1);	vZero(c2);	vZero(c3);	vZero(c4);	vZero(c5);
	vZero(c6);	vZero(c7);	vZero(c8);	vZero(c9);	vZero(c10);	vZero(c11);
	vZero(c12);	vZero(c13);	vZero(c14);	vZero(c15);	vZero(c16);	vZero(c17);
	vZero(c18);	vZero(c19);	vZero(c20);	vZero(c21);	vZero(c22);	vZero(c23);
	vZero(c24);	vZero(c25);	vZero(c26);	vZero(c27); vZero(c28);	vZero(c29);
	__assume_aligned(a, ALIGNMENT);
	__assume_aligned(b, ALIGNMENT);
	__assume_aligned(c, ALIGNMENT);
	__assume(size%16==0);
	for(int i = 0; i < size; i++) {
		const __m512d bv = _mm512_load_pd(b+i*size);
		c0 = _mm512_fmadd_pd(_mm512_extload_pd(a+i*size+0, _MM_UPCONV_PD_NONE, _MM_BROADCAST_1X8, 0), bv, c0);
		c1 = _mm512_fmadd_pd(_mm512_extload_pd(a+i*size+1, _MM_UPCONV_PD_NONE, _MM_BROADCAST_1X8, 0), bv, c1);
		c2 = _mm512_fmadd_pd(_mm512_extload_pd(a+i*size+2, _MM_UPCONV_PD_NONE, _MM_BROADCAST_1X8, 0), bv, c2);
		c3 = _mm512_fmadd_pd(_mm512_extload_pd(a+i*size+3, _MM_UPCONV_PD_NONE, _MM_BROADCAST_1X8, 0), bv, c3);
		c4 = _mm512_fmadd_pd(_mm512_extload_pd(a+i*size+4, _MM_UPCONV_PD_NONE, _MM_BROADCAST_1X8, 0), bv, c4);
		c5 = _mm512_fmadd_pd(_mm512_extload_pd(a+i*size+5, _MM_UPCONV_PD_NONE, _MM_BROADCAST_1X8, 0), bv, c5);
		c6 = _mm512_fmadd_pd(_mm512_extload_pd(a+i*size+6, _MM_UPCONV_PD_NONE, _MM_BROADCAST_1X8, 0), bv, c6);
		c7 = _mm512_fmadd_pd(_mm512_extload_pd(a+i*size+7, _MM_UPCONV_PD_NONE, _MM_BROADCAST_1X8, 0), bv, c7);
		c8 = _mm512_fmadd_pd(_mm512_extload_pd(a+i*size+8, _MM_UPCONV_PD_NONE, _MM_BROADCAST_1X8, 0), bv, c8);
		c9 = _mm512_fmadd_pd(_mm512_extload_pd(a+i*size+9, _MM_UPCONV_PD_NONE, _MM_BROADCAST_1X8, 0), bv, c9);
		c10 = _mm512_fmadd_pd(_mm512_extload_pd(a+i*size+10, _MM_UPCONV_PD_NONE, _MM_BROADCAST_1X8, 0),bv, c10);
		c11 = _mm512_fmadd_pd(_mm512_extload_pd(a+i*size+11, _MM_UPCONV_PD_NONE, _MM_BROADCAST_1X8, 0),bv, c11);
		c12 = _mm512_fmadd_pd(_mm512_extload_pd(a+i*size+12, _MM_UPCONV_PD_NONE, _MM_BROADCAST_1X8, 0), bv, c12);
		c13 = _mm512_fmadd_pd(_mm512_extload_pd(a+i*size+13, _MM_UPCONV_PD_NONE, _MM_BROADCAST_1X8, 0), bv, c13);
		c14 = _mm512_fmadd_pd(_mm512_extload_pd(a+i*size+14, _MM_UPCONV_PD_NONE, _MM_BROADCAST_1X8, 0), bv, c14);
		c15 = _mm512_fmadd_pd(_mm512_extload_pd(a+i*size+15, _MM_UPCONV_PD_NONE, _MM_BROADCAST_1X8, 0), bv, c15);
		c16 = _mm512_fmadd_pd(_mm512_extload_pd(a+i*size+16, _MM_UPCONV_PD_NONE, _MM_BROADCAST_1X8, 0), bv, c16);
		c17 = _mm512_fmadd_pd(_mm512_extload_pd(a+i*size+17, _MM_UPCONV_PD_NONE, _MM_BROADCAST_1X8, 0), bv, c17);
		c18 = _mm512_fmadd_pd(_mm512_extload_pd(a+i*size+18, _MM_UPCONV_PD_NONE, _MM_BROADCAST_1X8, 0), bv, c18);
		c19 = _mm512_fmadd_pd(_mm512_extload_pd(a+i*size+19, _MM_UPCONV_PD_NONE, _MM_BROADCAST_1X8, 0), bv, c19);
		c20 = _mm512_fmadd_pd(_mm512_extload_pd(a+i*size+20, _MM_UPCONV_PD_NONE, _MM_BROADCAST_1X8, 0), bv, c20);
		c21 = _mm512_fmadd_pd(_mm512_extload_pd(a+i*size+21, _MM_UPCONV_PD_NONE, _MM_BROADCAST_1X8, 0), bv, c21);
		c22 = _mm512_fmadd_pd(_mm512_extload_pd(a+i*size+22, _MM_UPCONV_PD_NONE, _MM_BROADCAST_1X8, 0), bv, c22);
		c23 = _mm512_fmadd_pd(_mm512_extload_pd(a+i*size+23, _MM_UPCONV_PD_NONE, _MM_BROADCAST_1X8, 0), bv, c23);
		c24 = _mm512_fmadd_pd(_mm512_extload_pd(a+i*size+24, _MM_UPCONV_PD_NONE, _MM_BROADCAST_1X8, 0), bv, c24);
		c25 = _mm512_fmadd_pd(_mm512_extload_pd(a+i*size+25, _MM_UPCONV_PD_NONE, _MM_BROADCAST_1X8, 0), bv, c25);
		c26 = _mm512_fmadd_pd(_mm512_extload_pd(a+i*size+26, _MM_UPCONV_PD_NONE, _MM_BROADCAST_1X8, 0), bv, c26);
		c27 = _mm512_fmadd_pd(_mm512_extload_pd(a+i*size+27, _MM_UPCONV_PD_NONE, _MM_BROADCAST_1X8, 0), bv, c27);
		c28 = _mm512_fmadd_pd(_mm512_extload_pd(a+i*size+28, _MM_UPCONV_PD_NONE, _MM_BROADCAST_1X8, 0), bv, c28);
		c29 = _mm512_fmadd_pd(_mm512_extload_pd(a+i*size+29, _MM_UPCONV_PD_NONE, _MM_BROADCAST_1X8, 0), bv, c29);
	_mm512_storenr_pd(c+0*size, c0);
	_mm512_storenr_pd(c+1*size, c1);
	_mm512_storenr_pd(c+2*size, c2);
	_mm512_storenr_pd(c+3*size, c3);
	_mm512_storenr_pd(c+4*size, c4);
	_mm512_storenr_pd(c+5*size, c5);
	_mm512_storenr_pd(c+6*size, c6);
	_mm512_storenr_pd(c+7*size, c7);
	_mm512_storenr_pd(c+8*size, c8);
	_mm512_storenr_pd(c+9*size, c9);
	_mm512_storenr_pd(c+10*size, c10);
	_mm512_storenr_pd(c+11*size, c11);
	_mm512_storenr_pd(c+12*size, c12);
	_mm512_storenr_pd(c+13*size, c13);
	_mm512_storenr_pd(c+14*size, c14);
	_mm512_storenr_pd(c+15*size, c15);
	_mm512_storenr_pd(c+16*size, c16);
	_mm512_storenr_pd(c+17*size, c17);
	_mm512_storenr_pd(c+18*size, c18);
	_mm512_storenr_pd(c+19*size, c19);
	_mm512_storenr_pd(c+20*size, c20);
	_mm512_storenr_pd(c+21*size, c21);
	_mm512_storenr_pd(c+22*size, c22);
	_mm512_storenr_pd(c+23*size, c23);
	_mm512_storenr_pd(c+24*size, c24);
	_mm512_storenr_pd(c+25*size, c25);
	_mm512_storenr_pd(c+26*size, c26);
	_mm512_storenr_pd(c+27*size, c27);
	_mm512_storenr_pd(c+28*size, c28);
	_mm512_storenr_pd(c+29*size, c29);
int main(int argc, const char ** argv) {
#ifdef SIZES
	const int size = SIZE;
#else
	const int size = atoi(argv[1]);
#endif
	void* p = malloc((sizeof(double)*5*size*size) + ALIGNMENT-1);
	double *__restrict__ a = (double*)(((size_t)p + ALIGNMENT-1) / ALIGNMENT * ALIGNMENT);
	double *__restrict__ aT = (double*) a+size*size;
	double *__restrict__ b = aT+size*size;
	double *__restrict__ c = b+size*size;
	double *__restrict__ d = c+size*size;
	srand(time(NULL));
		for(int j = 0; j < size; j++) {
			a[i*size+j] = (double) (rand()%20);
		for(int j2=0; j2<size; j2++){
			c[i*size+j2] = 0.0;
			b[i*size+j] = (double) (rand()%20);
	start_time();
	recTranspose(a, aT, size, size, size, size);
	for(int i = 0; i < size; i+=30) {
		for(int j = 0; j < size; j+=8) {
			eightbythirty(&aT, &b, &c[i*size+j], size);
	elapsed_time();
	double gflops = 2.0*size*size*size*1.0e-03/(microseconds);
	printf("Gflops: %f\n", gflops);
			double s = 0;
			for(int u = 0; u < size; u++) {
				s += a[i*size+u] * b[u*size+j];
			d[i*size+j] = s;
	int error = 0;
			if(abs(c[i*size+j] - d[i*size+j]) > 1) {
				printf("Error at %d %d , %f instead of %f\n", i, j, c[i*size+j], d[i*size+j]);
				error++;
				if(error > 16) return 0;
	printf("OK\n");
So for example, having size 960 (for now it works only with sizes multiples of 30*8):
  • if I compile with compile time given size: icc -mmic -O3 -restrict -std=c++11 -DSIZES -DSIZE=960 mmul.cpp -o mmul.o
    Elapsed time: 0.460745s
    Gflops: 3.840458
  • if I compile with runtime given size: icc -mmic -O3 -restrict -std=c++11 mmul.cpp -o mmul.o
    Elapsed time: 2.204564s
    Gflops: 0.802640
I'm thinking it could be a prefetching issue with icc that can't recognize the memory access pattern. Looking at the generated asm source, the number of vprefetch instructions is much more higher in the "compile time" version.
Funny fact: the check for the correct result of the multiplication (the two for loops at the end of the code, rows 178-197) is much more slower in the compile time version!
Any thoughts? I tried the #pragma loop_count but it seems it's useless, also doing manual intrinsic prefetching doesn't seem to be very effective.
Thanks in advance for any answer.
Luca
jimdempseyatthecove
I would check to see if register (zmm) pressure exceeds that of the number available.
You have defined 30 c's and your inner loop uses 1 for bv totaling 31. There are 32 available. Each _mm512_extload_pd will require one more temp register, meaning you reach the maximum number of zmm registers on your first _mm512_extload_pd. Though this "might" not make a difference on KNC architecture, it will make a difference on the future KNL architecture. And the compiler optimization may require a few spare registers. In looking at the disassembly of the eightbythirty you will be able to ascertain if some of your c's reverted to memory (stack) variables.
Jim Dempsey
Luca_A_
Thanks for the answer.
I checked and I think the number of available zmm registers is not exceeded.
Here's the asm of the version compiled without defines:
..B1.46:                        # Preds ..B1.48 ..B1.45 Latency 141
        incl	  %r9d                                          #170.3 c1
        movl	  152(%rsp), %r12d                              #171.43 c1
        lea	  (,%r9,8), %r10d                               #171.4 c5
        movq	  144(%rsp), %r11                               #171.27 c5
        movslq    %r10d, %r10                                   #171.27 c9
        lea	  (%r12,%r9,8), %r15d                           #171.43 c9
        lea	  -64(%r11,%r10,8), %rcx                        #171.27 c13
        movslq    %r15d, %r15                                   #171.34 c13
        movq	  136(%rsp), %r11                               #171.34 c17
        movl	  %r9d, 192(%rsp)                               # c17
        lea	  -64(%r11,%r15,8), %r12                        #171.34 c21
        xorl	  %r15d, %r15d                                  #171.4 c21
        vpxorq    %zmm0, %zmm0, %zmm0                           #171.4 c25
        xorl	  %r11d, %r11d                                  # c25
        vpxorq    %zmm1, %zmm1, %zmm1                           #171.4 c29
        movq	  160(%rsp), %r8                                # c29
        vpxorq    %zmm2, %zmm2, %zmm2                           #171.4 c33
        vpxorq    %zmm3, %zmm3, %zmm3                           #171.4 c37
        vpxorq    %zmm4, %zmm4, %zmm4                           #171.4 c41
        vpxorq    %zmm5, %zmm5, %zmm5                           #171.4 c45
        vpxorq    %zmm6, %zmm6, %zmm6                           #171.4 c49
        vpxorq    %zmm7, %zmm7, %zmm7                           #171.4 c53
        vpxorq    %zmm8, %zmm8, %zmm8                           #171.4 c57
        vpxorq    %zmm9, %zmm9, %zmm9                           #171.4 c61
        vpxorq    %zmm10, %zmm10, %zmm10                        #171.4 c65
        vpxorq    %zmm11, %zmm11, %zmm11                        #171.4 c69
        vpxorq    %zmm12, %zmm12, %zmm12                        #171.4 c73
        vpxorq    %zmm13, %zmm13, %zmm13                        #171.4 c77
        vpxorq    %zmm14, %zmm14, %zmm14                        #171.4 c81
        vpxorq    %zmm15, %zmm15, %zmm15                        #171.4 c85
        vpxorq    %zmm16, %zmm16, %zmm16                        #171.4 c89
        vpxorq    %zmm17, %zmm17, %zmm17                        #171.4 c93
        vpxorq    %zmm18, %zmm18, %zmm18                        #171.4 c97
        vpxorq    %zmm19, %zmm19, %zmm19                        #171.4 c101
        vpxorq    %zmm20, %zmm20, %zmm20                        #171.4 c105
        vpxorq    %zmm21, %zmm21, %zmm21                        #171.4 c109
        vpxorq    %zmm22, %zmm22, %zmm22                        #171.4 c113
        vpxorq    %zmm23, %zmm23, %zmm23                        #171.4 c117
        vpxorq    %zmm24, %zmm24, %zmm24                        #171.4 c121
        vpxorq    %zmm25, %zmm25, %zmm25                        #171.4 c125
        vpxorq    %zmm26, %zmm26, %zmm26                        #171.4 c129
        vpxorq    %zmm27, %zmm27, %zmm27                        #171.4 c133
        vpxorq    %zmm28, %zmm28, %zmm28                        #171.4 c137
        vpxorq    %zmm29, %zmm29, %zmm29                        #171.4 c141
And this is the version compiled with -DSIZES -DSIZE=960
..B1.21:    	                # Preds ..B1.21 ..B1.20 Latency 205
        vmovapd   (%rax,%r9,8), %zmm31                          #171.4 c1
        incl      %r10d                                         #171.4 c1
        vprefetch1 61440(%rax,%r9,8)                            #171.4 c5
        vfmadd231pd (%rbx,%r9,8){1to8}, %zmm31, %zmm30          #171.4 c9
        vprefetch0 15360(%rax,%r9,8)                            #171.4 c13
        vfmadd231pd 8(%rbx,%r9,8){1to8}, %zmm31, %zmm29         #171.4 c17
        vprefetch1 61440(%rbx,%r9,8)                            #171.4 c21
        vfmadd231pd 16(%rbx,%r9,8){1to8}, %zmm31, %zmm28  	#171.4 c25
        vprefetch0 15360(%rbx,%r9,8)                            #171.4 c29
        vfmadd231pd 24(%rbx,%r9,8){1to8}, %zmm31, %zmm27        #171.4 c33
        vprefetch1 61448(%r8)                                   #171.4 c37
        vfmadd231pd 32(%rbx,%r9,8){1to8}, %zmm31, %zmm26        #171.4 c41
        vprefetch0 15368(%r8)                                   #171.4 c45
        vfmadd231pd 40(%rbx,%r9,8){1to8}, %zmm31, %zmm25        #171.4 c49
        vprefetch1 61480(%r8)                                   #171.4 c53
        vfmadd231pd 48(%rbx,%r9,8){1to8}, %zmm31, %zmm24        #171.4 c57
        vprefetch0 15400(%r8)                                   #171.4 c61
        vfmadd231pd 56(%rbx,%r9,8){1to8}, %zmm31, %zmm23        #171.4 c65
        vprefetch1 61512(%r8)                                   #171.4 c69
        vfmadd231pd 64(%rbx,%r9,8){1to8}, %zmm31, %zmm22        #171.4 c73
        vprefetch0 15432(%r8)                                   #171.4 c77
        vfmadd231pd 72(%rbx,%r9,8){1to8}, %zmm31, %zmm21        #171.4 c81
        vprefetch1 61544(%r8)                                   #171.4 c85
        vfmadd231pd 80(%rbx,%r9,8){1to8}, %zmm31, %zmm20        #171.4 c89
        vprefetch0 15464(%r8)                                   #171.4 c93
        vfmadd231pd 88(%rbx,%r9,8){1to8}, %zmm31, %zmm19        #171.4 c97
        vprefetch1 61576(%r8)                                   #171.4 c101
        vfmadd231pd 96(%rbx,%r9,8){1to8}, %zmm31, %zmm18        #171.4 c105
        vprefetch0 15496(%r8)                                   #171.4 c109
        vfmadd231pd 104(%rbx,%r9,8){1to8}, %zmm31, %zmm17	#171.4 c113
        vprefetch1 61608(%r8)                                   #171.4 c117
        vfmadd231pd 112(%rbx,%r9,8){1to8}, %zmm31, %zmm16	#171.4 c121
        vprefetch0 15528(%r8)                                   #171.4 c125
        vfmadd231pd 120(%rbx,%r9,8){1to8}, %zmm31, %zmm15	#171.4 c129
        vprefetch1 61640(%r8)                                   #171.4 c133
        vfmadd231pd 128(%rbx,%r9,8){1to8}, %zmm31, %zmm14	#171.4 c137
        vprefetch0 15560(%r8)                                   #171.4 c141
        vfmadd231pd 136(%rbx,%r9,8){1to8}, %zmm31, %zmm13	#171.4 c145
        vprefetch1 61672(%r8)                                   #171.4 c149
        vfmadd231pd 144(%rbx,%r9,8){1to8}, %zmm31, %zmm12	#171.4 c153
        vprefetch0 15592(%r8)                                   #171.4 c157
        vfmadd231pd 152(%rbx,%r9,8){1to8}, %zmm31, %zmm11	#171.4 c161
        addq	  $7680, %r8                                    #171.4 c161
        vfmadd231pd 160(%rbx,%r9,8){1to8}, %zmm31, %zmm10	#171.4 c165
        vfmadd231pd 168(%rbx,%r9,8){1to8}, %zmm31, %zmm9        #171.4 c169
        vfmadd231pd 176(%rbx,%r9,8){1to8}, %zmm31, %zmm8        #171.4 c173
        vfmadd231pd 184(%rbx,%r9,8){1to8}, %zmm31, %zmm7        #171.4 c177
        vfmadd231pd 192(%rbx,%r9,8){1to8}, %zmm31, %zmm6        #171.4 c181
        vfmadd231pd 200(%rbx,%r9,8){1to8}, %zmm31, %zmm5        #171.4 c185
        vfmadd231pd 208(%rbx,%r9,8){1to8}, %zmm31, %zmm4        #171.4 c189
        vfmadd231pd 216(%rbx,%r9,8){1to8}, %zmm31, %zmm3        #171.4 c193
        vfmadd231pd 224(%rbx,%r9,8){1to8}, %zmm31, %zmm2        #171.4 c197
        vfmadd231pd 232(%rbx,%r9,8){1to8}, %zmm31, %zmm1        #171.4 c201
        addq	  $960, %r9                                       #171.4 c201
        cmpl	  $960, %r10d                                   #171.4 c205
        jb        ..B1.21	# Prob 82%                      #171.4 c205
Also, I compiled with -no-opt-prefetch, and the the performances collapse even in the "good" case (4.310070 s, 0.410544 GFLOPS), so it seems is all about prefetching.
jimdempseyatthecove
The one without the defines is not showing the compute section of the code, rather it is showing the zeroing section of of the c's. Please present the compute loop (the equivalent to the ..B1.21: ... through jb ..B1.21, though the label may differ).
Jim Dempsey
Luca_A_
Sorry, my mistake.
..B1.47:                        # Preds ..B1.46 ..B1.47 Latency 129
        movslq    %r11d, %r11                                   #171.4 c1
        incl	  %r15d                                         #171.4 c1
        vmovapd   (%rcx,%r11,8), %zmm30                         #171.4 c5
        lea	  (%r11,%r14,2), %r9d                           #171.4 c5
        vfmadd231pd (%r8,%r11,8){1to8}, %zmm30, %zmm0           #171.4 c9
        movslq    %r9d, %r9                                     #171.4 c9
        vfmadd231pd 8(%r8,%r11,8){1to8}, %zmm30, %zmm1          #171.4 c13
        vprefetch1 (%rcx,%r9,8)                                 #171.4 c13
        vfmadd231pd 16(%r8,%r11,8){1to8}, %zmm30, %zmm2         #171.4 c17
        vprefetch1 (%r8,%r9,8)                                  #171.4 c17
        vfmadd231pd 24(%r8,%r11,8){1to8}, %zmm30, %zmm3         #171.4 c21
        vfmadd231pd 32(%r8,%r11,8){1to8}, %zmm30, %zmm4         #171.4 c25
        vfmadd231pd 40(%r8,%r11,8){1to8}, %zmm30, %zmm5         #171.4 c29
        vfmadd231pd 48(%r8,%r11,8){1to8}, %zmm30, %zmm6         #171.4 c33
        vfmadd231pd 56(%r8,%r11,8){1to8}, %zmm30, %zmm7         #171.4 c37
        vfmadd231pd 64(%r8,%r11,8){1to8}, %zmm30, %zmm8         #171.4 c41
        vfmadd231pd 72(%r8,%r11,8){1to8}, %zmm30, %zmm9         #171.4 c45
        vfmadd231pd 80(%r8,%r11,8){1to8}, %zmm30, %zmm10        #171.4 c49
        vfmadd231pd 88(%r8,%r11,8){1to8}, %zmm30, %zmm11        #171.4 c53
        vfmadd231pd 96(%r8,%r11,8){1to8}, %zmm30, %zmm12        #171.4 c57
        vfmadd231pd 104(%r8,%r11,8){1to8}, %zmm30, %zmm13	#171.4 c61
        vfmadd231pd 112(%r8,%r11,8){1to8}, %zmm30, %zmm14	#171.4 c65
        vfmadd231pd 120(%r8,%r11,8){1to8}, %zmm30, %zmm15	#171.4 c69
        vfmadd231pd 128(%r8,%r11,8){1to8}, %zmm30, %zmm16	#171.4 c73
        vfmadd231pd 136(%r8,%r11,8){1to8}, %zmm30, %zmm17	#171.4 c77
        vfmadd231pd 144(%r8,%r11,8){1to8}, %zmm30, %zmm18	#171.4 c81
        vfmadd231pd 152(%r8,%r11,8){1to8}, %zmm30, %zmm19	#171.4 c85
        vfmadd231pd 160(%r8,%r11,8){1to8}, %zmm30, %zmm20	#171.4 c89
        vfmadd231pd 168(%r8,%r11,8){1to8}, %zmm30, %zmm21	#171.4 c93
        vfmadd231pd 176(%r8,%r11,8){1to8}, %zmm30, %zmm22	#171.4 c97
        vfmadd231pd 184(%r8,%r11,8){1to8}, %zmm30, %zmm23	#171.4 c101
        vfmadd231pd 192(%r8,%r11,8){1to8}, %zmm30, %zmm24	#171.4 c105
        vfmadd231pd 200(%r8,%r11,8){1to8}, %zmm30, %zmm25	#171.4 c109
        vfmadd231pd 208(%r8,%r11,8){1to8}, %zmm30, %zmm26	#171.4 c113
        vfmadd231pd 216(%r8,%r11,8){1to8}, %zmm30, %zmm27	#171.4 c117
        vfmadd231pd 224(%r8,%r11,8){1to8}, %zmm30, %zmm28	#171.4 c121
        vfmadd231pd 232(%r8,%r11,8){1to8}, %zmm30, %zmm29	#171.4 c125
        addl	  %r14d, %r11d                                  #171.4 c125
        cmpl	  %r14d, %r15d                                  #171.4 c129
        jb        ..B1.47	# Prob 82%                      #171.4 c129
jimdempseyatthecove
In the above code the vprefetch0's are missing as compared to the code using the #define'd size. This is what you were stating as an assumption (but now can prove).
Assuming the compilation options (and #pragmas) were the same, then this would indicate a deficiency in the auto prefetch insertion by the compiler.
It may be best if you can package this as a reproducer and send it on to Intel for analysis. Intel is always eager to have a good (and simple) reproducer that exposes inefficiency in their optimization.
Jim Dempsey
Kevin_D_Intel
I can submit this to Development for you Lucas for some additional investigation. Are you using the latest 15.0 compiler?
Luca_A_
Jim Dempsey
Yes it was exactly the same source code with identical compilation flags and pragmas.
Yes, I'm using the latest version.
If you would be so kind to submit it I can only say thank you!
TaylorIoTKidd
Note that there is another thread addressing this same topic on Stack Exchange with a different set of experts.
Kevin_D_Intel
Thank you Luca A. I submitted this to Development for further analysis (see internal tracking id below). I was unable to convince the compiler to increase the use of prefetches via any compiler option or directive. I will keep you posted on information I receive from Development.
(Internal tracking id: DPD200362905)
Luca_A_
How can I track it?
Kevin_D_Intel
You can't for the most part. Once closed the ids appear in the fixes list published with our releases. I will keep you updated as Development updates the ticket internally and you're welcome to ping for status in this thread at any time
