Software Archive
Read-only legacy content
17061 Discussions
intel.xdk.device.uuid
Lucas_Matias_G_
As are companions? I am having a problem using the "intel.xdk.device.uuid" property. When I did the test on the same intel XDK me worked fine, but when creating the apk to test it on my phone "motorola model g" with android 4.4.4, did not work me.
Would need to tell me if there is a problem with the property and should be so, as I can fix my downside? or there is some other method, function or whatever that allows me to do the same.
Thanks, greetings.
PaulF_IntelCorp
I just tried it on a real device and it works fine. Can you provide a simple example that illustrates the issue? Please zip your example project directory and files and attach it to this thread, do not provide just an index.html file, because it does not include important configuration information that might be the cause of the problem.
