Software Archive
Read-only legacy content
Popup com erro ao abrir a IDE do Intel XDK e Botão Edit Script que sumiu
Marcelo_Oliveira
Pessoal,
Sempre que abro meu Intel XDK, recebo segundos depois a mensagem de erro em anexo. Isso ocorria na versão 1878. Mas ao migrar para a versão 1912, o erro continua.
Outra coisa. Nessa versão final 1912, quando selecione um botão e desejo implementar um custom script, eu marco o botão, indico que quero um custom script na aba Interactivity, mas o botão "Edit Script" que deveria aparecer abaixo, na seção "interactivity" simplesmente não aparece.... É bug ???
Abraços,
Marcelo.
PaulF_IntelCorp
Whenever I open my Intel XDK , I get seconds after the error message attached. This occurred in version 1878. But when migrating to the 1912 version , the error continues.
Another thing. In this final version 1912, when select a button and wish to implement a custom script, I mark the button, indicate that want a custom script in the Interactivity tab , but the " Edit Script " button should appear below , in the " interactivity " simply not It appears .... bug ???
Marcelo .
Hello Marcelo,
Regarding the attached image and the error with adb, I have never seen that before, but it seems like an issue with your system. The program adb.exe is used by the Debug tab to connect to your Android devices for on-device debugging. It's possible your system has insufficient disk space or RAM.
Regarding the second issue, it could be related to my suspicions on the first...
Paul
Marcelo_Oliveira
Hi Paul,
I am sending now my system status, at the moment I received the error. As could be seem, I have memory and disk space to be able to run the Intel XDK IDE. I do not agree that my problem could be related to that.
My error appears, after a few seconds, before I start using the IDE.
My system configuration is:
Windows 8.1 Pro
8GB Ram
1 TB, in C: and 1.8 TB in D: My Intel XDK is installed in the default path at C:
AMD 6 cores 2.5Ghz
Marcelo.
PaulF_IntelCorp
Hello Marcelo,
If you start adb.exe at the command line, without starting the XDK at all, do you get this message? Here's how to conduct the experiment:
  1. restart your computer
  2. open a cmd.exe console
  3. at the cmd prompt, type:
    c:\users\marcelo\appdata\local\intel\xdk\bin\adb\adb.exe
  4. push "enter" after typing the above on the command line
  5. wait to see if you get the message (do not start the XDK)
  6. let me know the results
Also, do you have multiple copies of adb.exe on your system? You can find them by typing "dir /s adb.exe" at the command line, from the root of your drive (i.e., "cd \" before you issue the command). Might need to check both drives, depending on how you have organized your system.
Paul
Adimilton_A_
Seu código contém erros, por isto, o botão Edit Script não aprece. Procure corrigir o "index_user_script.js" que tudo voltará ao normal
