Software Archive
Read-only legacy content
Problemas para logar no software
Emerson_A_
olá boa tarde amigos,
Bom instalei o Intel XDK na minha máquina e não estou conseguindo fazendo login no software. Está dando erro de senha, mais no site da Intel loga normalmente.
Como resolver isso?
PaulF_IntelCorp
hello good afternoon friends ,
Good installed Intel XDK on my machine and I'm not getting by logging into the software. Is giving error password, more on Intel's site logs normally.
How to solve this?
Please try to log into this site with your XDK userid and password to confirm they are good. If you cannot log into that site with your XDK userid and password, please create a new account.
Emerson_A_
Hello friend,
Yes logging is usually on the Intel XDK site and not just logs in the program installed on my computer.
See the error print:error_xdk.jpg
PaulF_IntelCorp
I've asked someone who is familiar with the login system to take a look at your issue, this may be due to some changes in our authentication.
PaulF_IntelCorp
Your existing Intel account will not work with the XDK -- yet -- that is the change that is being implemented. You must create an XDK account by clicking the blue "Need to sign up for an account?" link below the login request. You can use the same userid and password as you current use for the Intel site, so when the merge of accounts happen yours will not have to change. But you must create a separate XDK account, at this time.
Robson_S_1
Boa noite
Primeiro não conseguia logar agora a janela para login não aparece.
Grato
Robson Santiago
Robson_S_1
Boa noite
Grato
Robson Santiago
Pamela_H_Intel
Robson,
The login window does not appear . . . what does appear? I am assuming you cannot use the XDK, but tell me what state it is in.
Robson_S_2
Pamela,
Thank you
Robson_S_2
PaulF_IntelCorp
It looks like you do not have a good network connection. Can you log into https://signin.intel.com/?
Robson_S_2
Yes, I do.
My connection is good.
PaulF_IntelCorp
Can you log in via the link I gave you?
Pamela_H_Intel
But what DO you see? Is the XDK window visible but grey so that you cannot click anything? The image you included DOES show the login window.
Eu tenho que entender o que acontece. Você diz que a janela para login não aparece. Mas que é visto? Só o XDK aparece? Mas é escuro?
Ou pode ser que tudo está bem sem janela para login seja mostrado? Mas se era esse, não houve um problema.
Ou é que a janela que venha não completa o processo. Mas ela venha mais uma vez, e mais uma vez, . . . ?
Pamela_H_Intel
Ah, I see. Sorry, I didn't see your post before I posted. Have you tried the link Paul gave you?
Robson_S_2
Goof afternoon
The problem continues , the login window is not visible and my connection is good.
PaulF_IntelCorp
Hello Robson, since you are able to post on this forum it means you have an account established and have a network connection. Are you using the same userid and password for the XDK as you are using for getting into this forum? If you have saved the password in your browser and are not sure of the password, please go to this page: https://signin.intel.com/ and confirm that you know the userid and password.
Please report back here your success regarding logging into this web site: https://signin.intel.com/ first so we can understand where the problem is coming from. We need to first determine if your userid and password are good. Do not start the XDK for this test, please use your browser and report back if you know your userid and password, first.
Robson_S_1
Hello, Paul
Success to connect in https://signin.intel.com/ . Used login : robsonsantiago2357@gmail.com and password
but the login window does not show.
Robson_S_1
Good Morning
Robson_S_1
Robson_S_1
