- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
Lien copié
- « Précédent
- Suivant »
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I finally managed to get the moninfo details for the monitor in question. I would now need the DTD lines for the drivers .inf file.
Monitor
Windows description......... Plug und Play-Monitor
Manufacturer description.... SANYO UK4
Manufacturer................ Sanyo
Plug and Play ID............ SAN0B0A
Serial number............... n/a
EDID data source............ Registry (stored)
Manufacture date............ 2007
EDID revision............... 1.2
Display type and signal..... Digital
Sync input support.......... Separate, Composite, Sync on green
Screen size................. 930 x 520 mm (~44")
Power management............ Standby
Color characteristics
Display gamma............... 2,30
Red chromaticity............ Rx 0,640 - Ry 0,330
Green chromaticity.......... Gx 0,290 - Gy 0,600
Blue chromaticity........... Bx 0,150 - By 0,060
White point (default)....... Wx 0,280 - Wy 0,290
Timing characteristics
VESA GTF support............ Not supported
Horizontal scan range....... 30-65kHz
Vertical scan range......... 59-61Hz
Video bandwidth............. 120MHz
Extension blocks............ n/a
Timing recommendation #1.... 1280x1024 at 60Hz
Modeline................ "1280x1024" 108,000 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync
Timing recommendation #2.... 1366x768 at 60Hz
Modeline................ "1366x768" 86,670 1366 1496 1632 1792 768 771 774 806 +hsync +vsync
Standard timings supported
640 x 480 at 60Hz - IBM VGA
640 x 480 at 60Hz - VESA
800 x 600 at 60Hz - VESA
1024 x 768 at 60Hz - VESA
1280 x 960 at 60Hz - VESA
1280 x 1024 at 60Hz - Sanyo
1360 x 765 at 60Hz - VESA
1366 x 768 at 60Hz - Sanyo
Raw EDID base
00: 00 FF FF FF FF FF FF 00 4C 2E 0A 0B 01 01 01 01
10: 00 11 01 02 8E 5D 34 82 8A E6 9D A3 54 4A 99 26
20: 0F 47 4A 21 08 00 31 40 45 40 61 40 81 40 8B C0
30: 01 01 01 01 01 01 30 2A 00 98 51 00 2A 40 30 70
40: 13 00 CB 90 32 00 00 1E 00 00 00 FD 00 3B 3D 1E
50: 41 0C 00 0A 20 20 20 20 20 20 DB 21 56 AA 51 00
60: 26 30 82 88 33 00 20 20 20 00 00 3E 00 00 00 FC
70: 00 53 41 4E 59 4F 20 55 4B 34 0A 20 20 20 00 28
Display adapter
Adapter description......... Mobile Intel 945 Express Chipset Family
Adapter device ID........... 0x27A28086
Display settings............ 850x480, 32bpp
User/computer information
Registered user name........ n/a
Registered organization..... n/a
Network user name........... n/a
Network computer name....... n/a
Windows version ............ Windows XP
Windows build .............. 5.01.2600 Service Pack 2
Installation date .......... n/a
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
DB 21 56 AA 51 00 26 30 82 88 33 00 20 20 20 00 00 3E
is what it says itwants for 1366x768.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Monitor
Windows description......... ViewSonic P655
Manufacturer................ ViewSonic
Plug and Play ID............ VSC4245
Serial number............... 28536 (81928536)
Manufacture date............ 1998, ISO week 19
EDID revision............... 1.0
Display type and signal..... Analog 0.700,0.300 (1.0V p-p)
Screen size................. 280 x 210 mm (~15")
Power management............ Standby, Suspend, Active off/sleep
Display gamma............... 2.60
Red chromaticity............ Rx 0.618 - Ry 0.350
Green chromaticity.......... Gx 0.280 - Gy 0.605
Blue chromaticity........... Bx 0.152 - By 0.063
White point (default)....... Wx 0.283 - Wy 0.298
Horizontal scan range....... 29-64kHz (est.)
Vertical scan range......... 48-75Hz (est.)
Video bandwidth............. 106MHz (est.)
Timing recommendation #1.... 1024x768 at 75Hz
Modeline................ "1024x768" 80.000 1024 1056 1152 1328 768 771 774 804 -hsync -vsync
Timing recommendation #2.... 640x400 at 70Hz
Modeline................ "640x400" 25.170 640 656 752 800 400 412 414 449 -hsync +vsync
Timing recommendation #3.... 1280x1024 at 60Hz
Modeline................ "1280x1024" 108.000 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync
Timing recommendation #4.... 1024x768 at 75Hz
Modeline................ "1024x768" 78.750 1024 1040 1136 1312 768 769 772 800 +hsync +vsync
640 x 400 at 70Hz - ViewSonic
640 x 480 at 75Hz - VESA
800 x 600 at 75Hz - VESA
832 x 624 at 75Hz - Mac II
832 x 624 at 75Hz - VESA
1024 x 768 at 75Hz - VESA
1024 x 768 at 75Hz - ViewSonic
1280 x 1024 at 60Hz - VESA
1280 x 1024 at 60Hz - ViewSonic
Raw EDID base
00: 00 FF FF FF FF FF FF 00 5A 63 45 42 78 6F 00 00
10: 13 08 01 00 0E 1C 15 A0 E8 6C 19 9E 59 47 9B 27
20: 10 48 4C 24 62 00 81 80 61 4F 49 4F 45 4F 31 4F
30: 31 40 31 40 31 40 40 1F 00 30 41 00 24 30 20 60
40: 33 00 10 CC 10 00 00 18 D5 09 80 A0 20 90 31 10
50: 10 60 C2 00 10 CC 10 00 00 1C 30 2A 00 98 51 00
60: 2A 40 30 70 13 00 10 CC 10 00 00 1E C3 1E 00 20
70: 41 00 20 30 10 60 13 00 10 CC 10 00 00 1E 00 0C
Display adapter
Adapter description......... Intel Q965/Q963 Express Chipset Family
Adapter device ID........... 0x29928086
Display settings............ 1024x768, 32bpp
Registered user name........ Microsoft
Registered organization..... Microsoft
Network user name........... Administrator
Network computer name....... GRISH
Windows version ............ Windows 2000
Windows build .............. 6.00.6001 Service Pack 1, v.735
help me
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Don't know why you're seeing different behavior in WinXP vs Vista, but if you use the DTD method you should be able to program 1024x768@85 with
Modeline "1024x768@85" 98.9 1024 1056 1216 1408 768 782 788 822 -HSync
-VSync
or in DTD language:
A2 26 00 80 41 00 36 30 20 A0 E6 00 00 00 00 00 00 18
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
are you able to give me the code vor 1680x1050 with 75Hz?
Thanks thanks thanks :-)
Marcus
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Please ask questions like this on support.intel.com. You'll get a faster response. This forum is for application coders.
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Intel is trying to limit this Forum to discussions of graphics software development. Fair enough, it's their board and they can set the agenda.
If support.intel.com is giving you no joy, my suggestion is
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi I know this is a intel forum but after days of searching you guys are the only place i can find with similair problems.
I have a 32 inch Samsung LCD TV and am supposed to be able to get 1368x768 resolution but keep getting 1024x768 and nothing either side of that, I have tried different ATI drivers but didn't help at all i ran moninfo and got this?!?!
Monitor
Hardware information........ n/a
Windows description......... Generic Non-PnP Monitor
Display adapter
Adapter description......... ATI RADEON XPRESS 200M Series
Adapter device ID........... 0x5A621002
Registered user name........ Lee
Network user name........... Lee
Network computer name....... LEE-PC
Windows build .............. 6.00.6000
Installation date .......... 25/03/2008 12:00:00
I am actually running vista not 2000.
I am guessing this is due to the fact that in Device manager under monitors it is picking this up as a Generic NON PnP Monitor, is there anyway around this?
Lee
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
How to modify the driver so that to change the max resolution 1024x576 of my Lenovo Ideapad S10e (Intel GMA 945), for example, to 1152x648 or 1232x696???
I tried everything with DTD Calculator and PowerStrip without any success!
Please for any help, idea and suggestion!
Thanks!
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
- « Précédent
- Suivant »
