Software Archive
Read-only legacy content
17061 Discussions
Question about MIC install
OpenHero
Does CentOS6.4 64bit can be sppported by MIC?
Linux version 2.6.32-358.2.1.el6.x86_64 (mockbuild@c6b8.bsys.dev.centos.org) (gcc version 4.4.7 20120313 (Red Hat 4.4.7-3) (GCC) ) #1 SMP Wed Mar 13 00:26:49 UTC 2013
03:00.0 Co-processor: Intel Corporation Device 225c (rev ff)
System Info
HOST OS : Linux
OS Version : 2.6.32-358.2.1.el6.x86_64
Driver Version : 5889-14
MPSS Version : 2.1.5889-14
miccheck 2.1.5889-14, created 18:10:54 Feb 28 2013
Copyright 2011-2013 Intel Corporation All rights reserved
Test 1 Ensure installation matches manifest : OK
Test 2 Ensure host driver is loaded : OK
Test 3 Ensure driver matches manifest : OK
Test 3> Error 0x2: No Intel(R) Xeon Phi(TM) Coprocessors in this system
Test 4 Detect all listed devices : SKIPPED
Test 4> Prerequisite 'Initialize the API' failed:
Test 4> Failed to initialize the API
Status: Error 0x2: No Intel(R) Xeon Phi(TM) Coprocessors in this system
TimP
CentOS equivalents of the supported Red Hat versions are known to work. If you mean CentOS 6.4, you would need the MPSS installation for Red Hat 6.4 (which I haven't seen), or you would need to attempt a rebuild of the micro-os kernel.  I think an earlier CentOS would be a better bet.
