The login problem should now be resolved (as of March 30 at 11:30 PDT). The workaround referenced in this thread should no longer be required. If you previously applied the workaround you do not need to "undo" or change anything, the workaround is compatible with the fix. You may be prompted to re-login if you were previously logged into the Intel XDK. The issue was due to the deployment of an incompatible authorization certificate.
------------------------ workaround no longer required ------------------------
Please see this post > https://software.intel.com/en-us/forums/intel-xdk/topic/720758#comment-1900352 < for a workaround.
------------------------ original post ------------------------
I received the following error.
The webpage at https://signin.intel.com/?appid=515&TYPE=33554433&REALMOID=06-900bfa3b-39d4-4f49-95b0-099aaaf63c20&GUID=&SMAUTHREASON=0&METHOD=GET&SMAGENTNAME=$SM$QnJMmP%2bN6gMN%2fVVnfgk5wOmI3XqRSADYbdE9VPLR1oGltLZwYJ6CRfT8RxFdy4HV&TARGET=$SM$HTTPS%3a%2f%2fsfederation%2eintel%2ecom%2ffederation%2fXDK_App_Center%2easp%3ftCulture%3den-US might be temporarily down or it may have moved permanently to a new web address.
链接已复制
Previously i did install it on custom directory. So I removed XDK and tried installing it on default directory, with admin privileges. It did not solve the issue and still getting the same error message after clicking log in or sign up.
A proper solution for the 3900 login issue is still being investigated.
If you are using the Intel XDK to complete the HTML5 from W3C Xseries instructional course, use Brackets instead and read this FAQ.
In the meantime, we have identified a workaround for the Intel XDK login issue. Please try it and report back on this thread if it works for you. The workaround described below is for a Windows system. Instructions for a similar workaround can be provided for OSX and Linux, if needed. If you are seeing this problem on Mac or Linux, please report here.
This workaround requires that you have Chrome 55 or greater installed on the same machine that you are using to run the Intel XDK.
- Close the Intel XDK.
- Make sure your system date and time is correct.
- Open a new tab in your Chrome browser (must be Chrome version 55 or later).
- Type https://appcenter.html5tools-software.intel.com/ into your Chrome browser.
- If you see a "Thank you for using the Intel® XDK." message in the browser, skip the next step, otherwise...
- Sign into the Chrome browser login page using your Intel XDK login username and password credentials.
- When you see a "Thank you for using the Intel® XDK." message in the browser, continue...
- Copy this file: "%LocalAppData%\Google\Chrome\User Data\Default\Cookies"
to this folder: "%LocalAppData%\XDK\User Data\Default"
(note there are spaces in the paths, so the double-quote characters are required!)
- After a successful copy operation, restart the Intel XDK and you should be automatically logged into your XDK account.
To perform the Cookies file copy using a Windows command prompt:
> cd "%LocalAppData%\XDK\User Data\Default" > copy "%LocalAppData%\Google\Chrome\User Data\Default\Cookies" . Overwrite .\Cookies? (Yes/No/All): y 1 file(s) copied.
IMPORTANT: do not forget the '.' character at the end of the copy command (above), it means "copy into this directory."
If your login times out, due to not using the XDK for an extended period of time (this usually takes a week or more), or you logout of the XDK, you may have to use this procedure again.
To create an account outside of the Intel XDK, goto https://software.intel.com/registration and follow the prompts.
Following is the same procedure, with some images included, for detail:
- After the copy, restart the Intel XDK and you should now be logged in.
Today i tried to build my app but i can't get to log in (i tried with 3 different computers), and so i can't build.
Is the build server of Intel XDK offline ?
Does someone know when it will become available ?
Does someone know when it will become available ?Thanks.
read the workaround
I have done as Paul F. (Intel) Fri, 03/17/2017 - 12:40 and Eduardo E. Fri, 03/17/2017 - 15:16 have recommended., i.e. Copy this file: "%LocalAppData%\Google\Chrome\User Data\Default\Cookies"
But still it does not work for me. I cannot login XDK to proceed! By the way, this is my first experience using this software. I use Visual Studio Code, and there is no problem like this.
(note there are spaces in the paths, so the double-quote characters are required!)But still it does not work for me. I cannot login XDK to proceed! By the way, this is my first experience using this software. I use Visual Studio Code, and there is no problem like this.
Did these steps succeed?
If the above steps worked, then you probably are not copying the "Cookies" file properly. Please try again.
I've done as was recommended. In the result, I have received the message mentioned:
If you are accessing this service from AppPreview, you may close the sign in window.
Again, I've copied the file: "%LocalAppData%\Google\Chrome\User Data\Default\Cookies"
to this folder: "%LocalAppData%\XDK\User Data\Default".
Now, when trying to enter XDK, a new window is opened "NW.js". So, what should I do then?
Artur -- do you also see a standard XDK window? Or just that NW window? I recommend doing the following:
- exit the XDK
- open a command prompt window (terminal)
- at the open command prompt, type the following commands:
> cd %LocalAppData%\XDK
> copy global-settings.xdk %UserProfile%\global-settings.old.xdk
> copy "User Data\Default\global-settings.xdk" %UserProfile%\global-settings.new.xdk
> rd /s /q *.*
> copy %UserProfile%\global-settings.*
> copy global-settings.old.xdk global-settings.xdk - start the XDK (it will likely not login)
- exit the XDK
- copy the Cookies file according to the workaround instructions
- start the XDK
Let me know if that works.
This bug affected me too. The workaround works fine for me.
During my app testing I had to change the system time, and this is exactly what caused the problem.
Maybe that will help you with the bug fix?
