Software Archive
Read-only legacy content
17060 Discussions
[RESOLVED] Cannot login to Intel XDK v3900
James_H_4
The login problem should now be resolved (as of March 30 at 11:30 PDT). The workaround referenced in this thread should no longer be required. If you previously applied the workaround you do not need to "undo" or change anything, the workaround is compatible with the fix. You may be prompted to re-login if you were previously logged into the Intel XDK. The issue was due to the deployment of an incompatible authorization certificate.
------------------------    workaround no longer required    ------------------------
Please see this post > https://software.intel.com/en-us/forums/intel-xdk/topic/720758#comment-1900352 < for a workaround.
------------------------    original post    ------------------------
I received the following error.
The webpage at https://signin.intel.com/?appid=515&TYPE=33554433&REALMOID=06-900bfa3b-39d4-4f49-95b0-099aaaf63c20&GUID=&SMAUTHREASON=0&METHOD=GET&SMAGENTNAME=$SM$QnJMmP%2bN6gMN%2fVVnfgk5wOmI3XqRSADYbdE9VPLR1oGltLZwYJ6CRfT8RxFdy4HV&TARGET=$SM$HTTPS%3a%2f%2fsfederation%2eintel%2ecom%2ffederation%2fXDK_App_Center%2easp%3ftCulture%3den-US might be temporarily down or it may have moved permanently to a new web address.
Maciej_Ż_
Workaround doesn't work for Ubuntu 16.04 and 16.10
PaulF_IntelCorp
The login problem should now be resolved, without having to use the workaround described in this thread. If you previously applied the workaround you do not need to "undo" or change anything, the workaround is compatible with the fix that has been applied. The issue was due to the deployment of some incompatible authorization certificates.
PaulF_IntelCorp
Naresh B. wrote:
When i click on Create Keystore, after filling description and alias it shows KEY PASSPHRASE IS REQUIRED...How to solve this?
https://software.intel.com/en-us/forums/intel-xdk/topic/721721
Krensa_D_
CANT SIGN UP INTEL XDK BECAUSE ACCSESS DENIED,  whyyyyyy
PaulF_IntelCorp
Can you provide a screenshot.
Norcio__Leandro
I cant login sad. i press the login button then it says loading and it pops up the sign up and loading button again
