Software Archive
Read-only legacy content
17061 Discussions
Re: Confused about DLLEXPORT
Steven_L_Intel1
The problem is that if you don't DLLEXPORT the variables, what you're getting is the locally defined versions in the module when you USE it. Importing variables and routines from a module in a DLL doesn't work well, partly because there's no good mechanism to say "don't look at the local definition of this routine/variable/etc., import it instead" This is something we need to work on.
What you could do, I think, is define a different module that has module-level variables and INTERFACE blocks, with appropriate ALIAS and DLLIMPORT attributes. I haven't tried this to see how it would work. We may need to invent some new syntax for this.
Steve
