Software Archive
Read-only legacy content
17060 Discussions
RealSense F200 How to get the width and height data , help !!!
edison_m_
edison_m_
anybody can help me , thanks a lot!!!
samontab
Valued Contributor II
edison_m_
samontab wrote:
When you receive an image, get its information:
https://software.intel.com/sites/landingpage/realsense/camera-sdk/v1.1/d...
Thanks a lot ,  samontab !
I want to know  the width and height data of a box
first , Save the picture by RealSense F200
and then get the data with PXCMImage , correct or not?
Whether , you can give me brief sample code (C#) , thank you very much!
samontab
When you receive the depth data, you can ask for the corresponding set of X, Y, Z points using the QueryVertices method:
https://software.intel.com/sites/landingpage/realsense/camera-sdk/v1.1/documentation/html/index.html?queryvertices_pxcprojection.html
If you know which 3D points correspond to each vertex of the box, then you can calculate its width and height by simply calculating the distance between them.
I recommend you to read the user manual, and have a look at the included examples.
edison_m_
hi,samontab:
     About the  examples,  whicth  one ?
      thanks !
edison_m_
hi,samontab:
      I got the 3D points(X, Y, Z point Lists)  By  QueryVertices method
How to calculate its width and height
very thanks!
samontab
hi,samontab:
very thanks!
Come on man, It's the euclidean distance of two points in 3D.
If you have point A, and B, the distance between them is:
sqrt( sum_i( (B_i - A_i)^2 ) ), for i=1..3
