Software Archive
Read-only legacy content
17060 Discussions
Recognize gesture if it is detected for particular interval / seconds
Khalil_S_
I want gesture to be Recognize only if it is detected for some seconds (3 secs).
camera should not consider it as gesture if hand gesture is changed before 3 secs.
How to achieve this ??
Any help appreciated.
Johannes_V_
Hello Khalil,
Some things I have seen that work really good are going over "votes" in the update method.
- detect the gesture and make a couple of votes for the recognized one ( at least 2)
- decrease the amount of votes for each gesture by 1 each step but only if the amount of votes for the gestures themselves is > 0
- at the end of update method, check if one of the gestures has enough votes to be taken as "winner". this is done by a specific thershold.
- if a winner has been found, dont forget to reset all votes.
I dont have this camera on my own so I "guessed" the following code, if there are problems, just tell me :
//GLOBAL variables:
int voteForGesture1 = 0, voteForGesture2 = 0 , voteForGesture3 = 0; // all of them
int thresholdForGestureDetection = 200 // lower this value for more detection, rise this value for less detection
// this looks like an updateFrame method?
int firedGesturesNumber = handAnalysis.QueryFiredGesturesNumber();
for(int i = 0; i < firedGesturesNumber; ++i)
                PXCMHandData.GestureData gestureData;
                if (handAnalysis.QueryFiredGestureData(i, out gestureData) == pxcmStatus.PXCM_STATUS_NO_ERROR)
                    if (handAnalysis.IsGestureFired("thumb_up", out gestureData))
                        gesnum = 1;
                    if (handAnalysis.IsGestureFired("v_sign", out gestureData))
                        gesnum = 2;
//this looks like a validate method at the end of each frame?
if(voteForGesture1>0)
    voteForGesture1--;
if(voteForGesture2>0)
    voteForGesture2--;
if(voteForGesture3>0)
    voteForGesture3--;
 switch (gesNum)
                    case 1:
                        voteForGesture1+=3;break;
                    case 2:
                        voteForGesture2+=3;break;
                    case 3:
                        voteForGesture3+=3;break;
if (voteForGesture1 >= thresholdForGestureDetection){
       label1.Content = "Gestured Fired 01 thumb Up ";
       voteForGesture1=0;
       voteForGesture2=0;
       voteForGesture3=0;
if (voteForGesture2 >= thresholdForGestureDetection){
    label1.Content = "Gestured Fired 02 V sign ";
    voteForGesture1=0;
    voteForGesture2=0;
    voteForGesture3=0;
Johannes_V_
So you want the hands to be not moved for 3 seconds and then recognize gestures?
I would try some method like checkHandMotion() and repeatedly measure its status. (f.e. returns 0 if hand not moved).
You would probably need to run this method about every 50ms or so. save the results for up to 3 seconds and then check over the saved results if the hand has moved during the last 3 seconds. if no movement && detected gesture then execute a command
if you have a minimum example for the recognition post the code here, i will try to give more details then
Khalil_S_
I am using many gestures in my project ,
and it detects gestures very quickly even when i don't do that gesture,
thus i want it to detect only if user do gesture for particular interval(3 secs) .i.e v-sign for 3 sec then only it must perform action assigned on v-sign and so on.
Johannes_V_
What camera do you have? Do you have some code?
Khalil_S_
I am using SR-300 camera.
Khalil_S_
From hand Analysis -
for(int i = 0; i < firedGesturesNumber; i++)
                        gesnum = 1;
                        gesnum = 2;
gesnum here is global variable which i am assigning manually and using it below in updateUi method in switch case -
under updateUi method -
 switch (gesNum)
                    case 1:
                      break;
                      case 1=2:
                      break;
And so on.
Johannes_V_
Hello Khalil,
//GLOBAL variables:
                        gesnum = 1;
                        gesnum = 2;
    voteForGesture1--;
    voteForGesture2--;
    voteForGesture3--;
 switch (gesNum)
                    case 1:
                    case 2:
                    case 3:
       voteForGesture1=0;
       voteForGesture2=0;
       voteForGesture3=0;
    voteForGesture1=0;
    voteForGesture2=0;
    voteForGesture3=0;
Khalil_S_
Thank you johannes,
i am implementing it.
Khalil_S_
Thank you Johannes, Code worked for me.
