Software Archive
Read-only legacy content
17060 Discussions
ReconOS Project in Android Studio
Jeffrey_J_
Hi, I am following along to the 'Using the ReconOS SDK Map Component' document to start building an application for the Recon Jet (Enterprise) headset. As described in the document, I've added the maven repository to the build.gradle(Project:ReconApp) file, added the recon SDK packages to the build.gradle(Module:app) file, and updated the manifest. However, when compiling I get the following errors:
“Failed to resolve: com.reconinstruments.app:recon-application:4.4.0”
“Failed to resolve: com.reconinstruments.os:recon-platform:4.4.0”
“Failed to resolve: com.reconinstruments.ui:recon-ui:4.4.0”
Please let me know how I can troubleshoot this problem, any help would be greatly appreciated!
Below are my build.gradle files:
build.gradle(Project):
buildscript {
    repositories {
        jcenter()
    dependencies {
        classpath 'com.android.tools.build:gradle:2.2.2'
        // NOTE: Do not place your application dependencies here; they belong
        // in the individual module build.gradle files
allprojects {
    repositories {
        jcenter()
        maven {
            url "http://repo.reconinstruments.com/artifactory/libs-release"
task clean(type: Delete) {
    delete rootProject.buildDir
build.gradle(Module):
apply plugin: 'com.android.application'
android {
    compileSdkVersion 25
    buildToolsVersion "24.0.2"
    defaultConfig {
        applicationId "blackberry.reconapp"
        minSdkVersion 16
        targetSdkVersion 16
        versionCode 1
        versionName "1.0"
        testInstrumentationRunner "android.support.test.runner.AndroidJUnitRunner"
    buildTypes {
        release {
            minifyEnabled false
            proguardFiles getDefaultProguardFile('proguard-android.txt'), 'proguard-rules.pro'
dependencies {
    compile fileTree(dir: 'libs', include: ['*.jar'])
    androidTestCompile('com.android.support.test.espresso:espresso-core:2.2.2', {
        exclude group: 'com.android.support', module: 'support-annotations'
    compile 'com.android.support:appcompat-v7:25.0.1'
    testCompile 'junit:junit:4.12'
    compile 'com.reconinstruments.app:recon-application:4.4.0'
    compile 'com.reconinstruments.ui:recon-ui:4.4.0'
    provided 'com.reconinstruments.os:recon-platform:4.4.0'
