Software Archive
Read-only legacy content
17061 Discussions
Rehosting a few fortran floating license from one location to another.
jagminder_chugh
We have around 100 floating licenses in one location which are accessed by windows clients located in another location across WAN.
Due to latency, check-in and check-out is slow.
We want to move some number of floating licenses from the present location and host it on a new server in the location where clients are located so that check-in and check-out is within LAN.
Is this possible?
If yes, can you please let us know the steps to do accomplish this.
Jagminder
Shamla_P_Intel
Is this license you are referring too from a single serial number?
Do you want to split this into 2 serial numbers and use one of them on a different server?
Am I correct?
Thank You
Shamla
jagminder_chugh
Hi Shamla,
That is correct.
We want to split the licenses and host it on a different server.
Please advice if this is possible.
Jagminder
Shamla_P_Intel
What is the serial number? I may not have permissions to do this. Do you know the e-mail address of the person whom you work with at Intel Site? I can request the team to see, if this can be done.
Thank You
Shamla
