Software Archive
Read-only legacy content
17061 Discussions
Renaming project copying www file
Tester_D_
Hello everyone!
I'm trying to rename a project by creating a second one on XDK and then copying the original www file in the second. The problem is that when I debug or download the second project via App Preview I only get a blank project page with a "Hello Cordova!". Shoudn't it be getting the reference of the new www file I replaced?
I'm aware of FAQ #34, I tried to set projectGuid to all zeros with no luck.
Thanks in advance!
Erik
Anusha_M_Intel1
So you replaced your WWW directory and added the necessary plugins and it is still not working?
Try this: make a copy of your old project directory -> remove .xdk, .xdke files -> import as HTML5 project (select yes for Cordova project and yes/no for game project). When you import, it will ask you to name your project.
Don't delete the 'plugins' directory. This will auto-collate the plugins in your new project so you don't have to add them manually.
John_H_Intel2
You should just create a new blank project in the XDK, then copy over you www folder and setup the settings in the XDK to match that of what the first one is.
Tester_D_
I created a new blank Cordova project in the second project, in which I added all of the first project necessary plugins via "Plugin Management" tab, but that was the only adjustment I thought I needed to do. What setup am I missing?
Thank you for your reply.
Erik
Anusha_M_Intel1
Deepak_S_1
Hi Anusha,
10/10
Great solution. Using it, i am now able to change the project name which was wrongly selected (due to typo).
Thanks for your solution.
Regards.
Ricardozo
OMG! Anusha you are the best! I owe you a cold beer!!!
