Software Archive
Read-only legacy content
[Resolved] IOS - Error: Plugin "BarcodeScanner" failed to install
Mitchell_Franklin
Hi All,
I am having build failure for IOS due to the phonegap-plugin-barcodescanner plugin for IOS.
I am currently using Intel XDK 2893. I have tried changing versions 4x and 3x with the same error, a couple of weeks ago there was no issue and no code has changed except for updating the status bar plugin to the latest version so not sure of what is occuring.
  • Will use the provisioning profile for "adhoc"
  • Error: Plugin "BarcodeScanner" failed to install.
  • Plugin "cordova-plugin-statusbar" (2.0.0) installed.
  • Plugin "cordova-plugin-device" (1.1.0) installed.
  • Plugin "cordova-plugin-splashscreen" (3.0.0) installed.
Any thoughts or support that could be provided would be greatly appreciated.
Mitch
John_H_Intel2
What other plugins are you using? I added the plugins you listed above and build just fine for iOS. Are you adding the plugins via the GUI in the XDK?
Build Log:
  • Building a Cordova 5.1.1 application.
  • The application name is "App2"
  • The package name is "com.teamjph.nothing.jan"
  • Plugin "cordova-plugin-splashscreen" (2.1.0) installed.
  • Plugin "phonegap-plugin-barcodescanner" (4.1.0) installed.
  • Targeting iOS version 6.
Mitchell_Franklin
Hi John,
The plugins have been added via the GUI - project was created prior to the GUI being as it is now so was added via Intel by providing the github address and version etc. - could there be some old code still valid?
Below is the full build log i get
Build Log:
  • The application name is "Discount Check"
  • The package name is "mjs.productions.srg.discount.check"
Mitch
Amrita_C_Intel
Which barcode scanner version are you using?
Mitchell_Franklin
Hi Amrita,
I have tried the 3x and 4x versions to see if it was something to do with that but still had the same issue
Ta
Mitch
John_H_Intel2
I believe the issue is with NPM itself. I tried building later, and the plugin failed to install, even through I didnt change anything. It seems like the registry is having connection issues sporadically. You can try downloading the plugin and then adding it as a local plugin via the GUI interface.
Mitchell_Franklin
Hi John & Amrita,
Thank you for looking into this, it took a couple times through out the day and as you suspected it does work but an unknown NPM connection issues.
As always your support is awesome.
Ta
Mitch
