Software Archive
Read-only legacy content
Saving color and depth frames
varsha_h_
Hey all, I'm working on Intel RealSense SDK (R2). I want to save the image from Camera_viewer. I have worked till saving the frame to specific buffers and retrieving from the same. I want to know how to save those frames/images to a specified location/folder.
Here's my code:
    PXCImage *colorIm, *depthIm;
    for (int i=0; i<MAX_FRAMES; i++) {
        // This function blocks until all streams are ready (depth and color)
        // if false streams will be unaligned
        if (psm->AcquireFrame(true)<PXC_STATUS_NO_ERROR) break;
        // retrieve all available image samples
        PXCCapture::Sample *sample = psm->QuerySample();
        // retrieve the image or frame by type from the sample
        colorIm = sample->color;
        depthIm = sample->depth;
        // render the frame
        if (!renderColor->RenderFrame(colorIm)) break;
        if (!renderDepth->RenderFrame(depthIm)) break;
        // release or unlock the current frame to fetch the next frame
        psm->ReleaseFrame();
I'm able to retrieve the frames/images successfully, but I want to save those files for further use. So I want to know how to save those files in a folder.
Thanks in advance
Dan_Middleton
The CaptureManager has a SetFileName method that will let you record to a file.  There's an example in the SDK documentation you might find helpful:
void RecordORPlayback(pxcCHAR *file, bool record) {
   // Create a SenseManager instance
   PXCSenseManager *sm=PXCSenseManager::CreateInstance();
   // Set file recording or playback
   sm->QueryCaptureManager()->SetFileName(file,record);
   // Select the color stream
   sm->EnableStream(PXCCapture.STREAM_TYPE_COLOR,640,480,0);
   // Initialize and Record 300 frames
   sm->Init();
   for (int i=0;i<300;i++) {
       // This function blocks until a color sample is ready
       if (sm->AcquireFrame(true)<PXC_STATUS_NO_ERROR) break;
       // Retrieve the sample
       PXCCapture::Sample *sample=sm->QuerySample();
       // Work on the image sample->color
       // Go fetching the next sample
       sm->ReleaseFrame();
   // close down
   sm->Release();
varsha_h_
Thank you so much.
varsha_h_
@Dan
As you have suggested I have tried the same using a function. But I'm not able to record the frames to a specified folder. I have attached the file, please correct me if I'm wrong
Lesly_Z_
hey!
how can I apply the same for librealsense?
I am trying to use:
RS_STREAM_COLOR_ALIGNED_TO_DEPTH
for getting something similar to the example in cpp-align
thanks
