Software Archive
Read-only legacy content
17060 Discussions
Segfault with asynchronous offload
aketh_t_
Hi
I am facing a segmentation fault problem when I try to perform asynchronous offload at a later point which I believe is the time when the function returned.
here is the code
functionA
real :: WORKN(X,Y,Z)
!dir$ offload begin target(MIC:0)signal(1)out(WORKN)
   do k=1,km
           !Lots of code
!dir$ end offload
end function A
functionB
real :: Dummy
! Do Whatever
end function B
program run
!$OMP PARALLEL DO DEFAULT(SHARED) !this OMP is dummy i.e num_blockblock is 1, can be removed
do iblock=1,num_blocks
      call functionA(iblock) !here is the async offload
enddo
!$OMP END PARALLEL DO
      call functionB(iblock) get segfault when B is running
enddo
end program run
Ravi_N_Intel
Where do you wait for the async offload to be completed.  I don't see it in the code you posted.  I could speculate that  the async offload completed after your main program exited since I don't see the wait for the async offload.
Best if you can provide us a small reproduce.
Rajiv_D_Intel
Without the save attribute, WORKN is a stack variable. You issue an offload which writes into it, and then you return from the function. At some point in time, a write to WORKN occurs, potentially, outside the stack, or into the stack frame of another function.
That is most likely the cause of the problem.
jimdempseyatthecove
Also, you cannot use the same signal for multiple threads. Each thread should use a different signal value, you might consider using a reference to a thread stack local variable or a unique variable to the thread, such as the thread ID. *** The OpenMP omp_get_thread_num() will not be a unique number in the event of nested parallelism, so be careful about using that for a unique number.
As mentioned by others, you should also have a signal wait.
Jim Dempsey
aketh_t_
The problem was the missing wait statement. Thank you guys.
