Software Archive
Read-only legacy content
Seismic Unix Native Compiled for MIC not working on MIC
Abhishek_S_7
Dear All,
I have native compiled Seismic Unix - 42 (SU) from CWP for MIC. Added its library path to LD_LIBRARY_PATH of MIC. When I try to see the description of commands of  SU on MIC than it is displayed but while executing normal comands like suedit or surange for any .su or .segy file it is giving error "suedit: fgettr.c: no data on first trace".
Please help to resolve the issue.
Abhishek
Vladimir_P_1234567890
hello,
do you provide the path to .su files located on the card or on the host?
--Vladimir
Abhishek_S_7
.su files are located on host whose file system is nfs mounted on card. I can see the file on card.
Frances_R_Intel
You are logging into the coprocessor and executing from the command prompt and not using something like micnativeloadex, right? I ask this because micnativeloadex does not run from your home directory on the coprocessor.
Gregg_S_Intel
Check for errors generating SU include files prehdr.h and offsets.h.  Problems generating these header files would cause the error message you're seeing.
Abhishek_S_7
Hi Roth,
I compiled SU in native mode and executing the executable on coprocessor and not using micnativeloadex.
Abhishek_S_7
Hi Gregg,
There is no  prehdr.h and offsets.h header files either in native compiled SU or host compiled SU. SU on host is working fine. Non -SU commands like pswigb, psimage, unif2, b2a are working on coprocessor but su commands like suedit, surange are not working on coprocessor.
Gregg_S_Intel
Look in src/su/include.
I can reproduce the behavior you're describing by changing CPP in src/Makefile.config to something bogus.  The build completes, but upon closer inspection there are errors creating prehdr.h and offsets.h, and the message, "fgettr.c: no data on first trace" appears when a MIC executable tries to read input.  (I encountered this same issue myself building SU for the first time, because I had mistakenly changed the CPP command.)
