Software Archive
Read-only legacy content
Serial Number Not Valid - Community Licensing for Intel® Performance Libraries
Jean_R_
I registered to the Community Licensing for Intel® Performance Libraries and got a serial number, with links to download files.
Having downloaded the MKL install package for Linux, I find it impossible to install the library as the serial number gets rejected; here is the message I receive during the installation process:
"The serial number you provided is not valid for product Intel(R) Math Kernel Library 2017 for Linux"
Any help would be much appreciated.
Many thanks,
Jean
Light_Intel
For those who encounter the issue on Linux*:
We don’t have full support of spaces in paths in 2017 products. Please remove all the spaces from the path to the package.
Noga
Light_Intel
Thank you for contacting Intel Support.
When attempting to install Intel MKL what do you use for activation? Do you choose to activate using a license file or using the SN (serial number) you received from Intel Registration Center? Can you please attach an image of the error message in a private message?
Noga
Intel Developer Support
Light_Intel
BTW, I see that the product was installed on one system already. Are you trying to install it on an additional system?
Noga
Jean_R_
Hi Noga,
Thank for your prompt replies. Let me answer both of your questions here:
1) I tried to activate with the serial number as well as license file, but neither worked so I removed the license file.
2) I can confirm that I have NOT installed this library on any of my computers. I just registered yesterday and tried to install it on my laptop, but it didn't work (as per my original message).
Jean_R_
I would really appreciate some assistance with this as I am left unable to install the library.
In case you sent me a serial number that was already being used by someone else, would it not be possible for you to reset the serial number linked to my account?
Many thanks,
Jean
Light_Intel
I was able to duplicate your issue and have escalated it. I will keep you updated.
Noga
Timothy_F_
Has this been resolved? I have been having the same issue with neither the SN or license file working.
Jean_R_
No this has not been resolved yet, though Intel have acknowledged / replicated the issue.
Light_Intel
I need to see the installation logs. Please do the following:
# export INTEL_LMD_DEBUG=/tmp/lic_debug.log
Run the installer
Please send /tmp/lic_debug.log to me. Make sure to do it in a private message to protect your information.
Noga
Light_Intel
Noga
Victor_S_1
I was with this same problem.
Victor
Jean_R_
Yes I can confirm that solved the issue for me:
Light_Intel
This issue had been resolved, please see BEST REPLY.
