Software Archive
Read-only legacy content
17060 Discussions
Side Menu Lag on some android device
Ronald_H_2
  I am developing an app using framework 7 in intel xdk, and i found that its side menu lag on some android device (in this case Samsung Note 3)
May I know why? and is there any solution for this?
Elroy_A_Intel
If you are noticing a different experience per device, this could be related to the web view rending engine on each device. You can write your own optimized functions/implementations if necessary, but this could be an issue with framework 7 running on some Android devices as well.
PaulF_IntelCorp
I recommend you build with Crosswalk and compare the results when using Crosswalk.
