Software Archive
Read-only legacy content
17060 Discussions
Simple feature request
René_S_
Every time I create the Cordova build package I get a zip file called [appname]-pgb-cli-2017-0718-20117.zip. Looks ok, but I have a request: Could the time at the end of the filename please be formatted with leading zero's (always 6 digits), so the files will be displayed in the right order?
When you are creating several build packages in a short time (like I do sometimes) this would really make a difference. Thanks!
PaulF_IntelCorp
Thanks for the feedback. In fact, those date-stamped config.xml files are named like that to avoid confusion with the config.xml file that is being generated. They only appear if you have a config.xml file in the root of the project folder when you run the export tool. I know that if you do not complete the process (e.g., start the export but do not save the ZIP) the export tool can leave a config.xml file behind, in the project folder. If you follow through and the process does not fail, you should not see these time-stamped config.xml files. This is just a very long way of saying that those time-stamped files are an artifact, not a feature, to insure we do not wipe out anything that you may already have in your project folder. We are not trying to manage those files.
