Software Archive
Read-only legacy content
17060 Discussions
Swipe left/right not working since upgrade to XDK build 2548
Forrest_W_1
Help!
I have an app called FoodieSpotz that has both left-side and right-side (aside) menus using Intel App Framework.
Prior to the upgrade to XDK build 2548, when testing using Local Apps (wi-fi) or using Server Apps through App Preview, the left/right swipe worked.
It is no longer working.  It works in the emulator, but not on the device.
Anchor buttons to open up the left/right menus still work, but swiping to open up the left or right menus from the main panel no longer works.
Please advise.
Forrest Ward
Elroy_A_Intel
What type of device are you testing on? What version of App Framework are you using?
Forrest_W_1
Elroy,
I have tried testing FoodieSpotz app on both a Galaxy S2 and a new Samsung Note 5 - swipe left/right does not work on either device.
My script tag in my application for AppFramework is:
        <script type="text/javascript" charset="utf-8" src="js/appframework.ui.min.js"></script>
Inside the AppFramework JavaScript file is:
/*! intel-appframework - v2.1.0 - 2014-11-06 */
This problem (swipe left / swipe right) to access the leftsideMenu and rightsideMenu on the FoodieSpotz app did not start until the XDK upgrade but could have started with the App Preview app upgrade.
Either way, what once worked flawlessly does not work now.
Please advise what needs to be done to fix this.
The code I'm using for left and right menu(s) and follows:
LEFT MENU:
            <!-- default sidemenu -->
            <nav id="default_sidemenu" title="Options">
                <ul class="list">
                 <li class="divider">Main Menu</li>
                    <li><a href="#main" data-transition="none" onclick="loadedPanel();$.ui.toggleLeftSideMenu();">Home</a></li>
                    <li><a href="#javascript:;" data-transition="none" onclick="loadGSFavorites();">My Favorites</a></li>
                    <li><a href="#my_rewards" data-transition="none">My Rewards</a></li>
                    <li><a href="#my_messages" data-transition="none">My Messages</a></li>
                    <li><a href="#my_emails" data-transition="none">My Emails</a></li>
                    <li><a href="#corporate_fabrics" data-transition="none">Corporate Brands</a></li>
                 <li class="divider">Settings</li>
                    <li><a href="#my_location" data-transition="none" onclick="resetMap();$.ui.slideSideMenu=false;">My Location</a></li>
                    <li><a href="#javascript:;" data-transition="none" onclick="showProfile();$.ui.slideSideMenu=false;">My Profile</a></li>
                 <li class="divider">Utilities</li>
                    <li><a href="index.html" data-ignore="true">Restart App</a></li>
                </ul>
            </nav>
RIGHT (aside) MENU:
            <!-- aside menu -->
                <aside>
                    <header class="header">
                        <h1>Fabrics</h1>
                        <a onclick='af.ui.toggleRightSideMenu()' class="button icon pin"></a>
                    </header>
                    <ul id="asidemenu" class="list">
                        <li class="divider">Food & Drink</li>
                        <!-- APPEND fabric network listing here -->
                    </ul>
                </aside>
The code above still works in the EMULATOR ... but does not work in App Preview on my Android device(s).
Please note - the AppFramework Documentation no longer supports "aside" for the rightMenu.
