Software Archive
Read-only legacy content
Systemqq
Intel_C_Intel
I tried using systemqq to launch winword, as follows:
l4 = systemqq('winword c:myfile.doc')
Apparently no success, as winword is not launched. However,
l4 is returned as .TRUE.
Was ist los?
LKD
winword would have to be in your PATH to make this work.
Have you considered the ShellExecute API routine? You could use it to "open" the document. I have used this many times with great success. It will automatically open the document using the default associated with the file type, including web pages!
Steve
Intel_C_Intel
Ah yes, the path. Actually, I did use the complete path, but still no luck. I still can't figure out why winword is not launched. However, your suggestion to use ShellExecute is a much better idea, and I will try it later today.
lkd
P.. If I weren't already using CVF, I would certainly buy it based on the great support!
If the complete path had spaces in it, you would need to enclose the path in "".
Steve
Intel_C_Intel
Tried ShellExecute today. Here is the command I used:
i4 = ShellExecute( GetHWndQQ(QWIN$FRAMEWINDOW), "OPEN", "c:2maxents.DOC", " ", " ", %VAL(0) )
i4 = 31 upon return. (No association for this file extension). I'm running all this under Win2000. I checked my associations. Indeed DOC is registered to Word.
What should I do next to figure out what the real problem is?
lkd
ShellExecute is a Win32 routine, so all strings must be C strings - for example, "OPEN"C.
Steve
Intel_C_Intel
Yes, and so my MSDN documentation said. This was my first attempt:
i4 = ShellExecute( GetHWndQQ(QWIN$FRAMEWINDOW), "OPEN"C, "c:2maxents.DOC"C, " "C, " "C, %VAL(0) )
Returned i4 = 2 (File not found).
And my third attempt, assuming that I couldn't pass a null-terminated string in such an implicit way, was this:
str1 = "OPEN"C
str2 = "c:2maxents.DOC"C
str3 = ""C
i4 = ShellExecute( GetHWndQQ(QWIN$FRAMEWINDOW), str1, str2, str3, str3, %VAL(0) )
Returned i4 = 2 as above.
Question remains: Do you have any hints for debugging this?
lkd
Intel_C_Intel
This works
i4 = ShellExecute( GetHWndQQ(QWIN$FRAMEWINDOW), "OPEN"C, "2maxents.DOC"C, ""C, "c:"C, %VAL(0) )
This does not work
i4 = ShellExecute( GetHWndQQ(QWIN$FRAMEWINDOW), "OPEN"C, "c:2maxents.DOC"C, ""C, ""C, %VAL(0) )
nijhuis
LSD,
Your real problem is the backlash in the -string. "2" is a correct escape sequence in a -string and has the decimal value 2.
You should use a double backlash in the string: "I:2maxents.DOC"I
Gnus
nijhuis
LKD,
Sorry for the prior message. I misused the Spell Check.
Your real problem is the backslash in the C-string. "2" is a correct escape sequence in a C-string and has the decimal value 2.
You should use a double backslash in the string: "C:2maxents.DOC"C
Guus
Intel_C_Intel
Thanks Guus, that was EXACTLY the problem!
lkd
