Software Archive
Read-only legacy content
17060 Discussions
The Intel XDK Simulator does not work properly with Windows Server 2012
Mohamed_Ali_B_
The Intel XDK Simulator does not work properly with Windows Server 2012:
I used intel xdk Version 3522 with WIndows Server 2012 but the problem that the simulator and even Intel XDK him even crashes .For example if I use the simulator and I want to see the Resources section, it crashes
and nothing works.
and I have to restart Intel XDK and I lose my changes in the project.
Is it an issue with the Windows Server 2012?
Thank you in advance for your help..
PaulF_IntelCorp
We only test and support Windows 7, 8.x and 10 systems. The XDK is not tested or validated on Windows server systems.
Mohamed_Ali_B_
Hi Paul, I have the same problem with Windows 7 OS System
PaulF_IntelCorp
Did you attempt to install in a non-standard location? Let the XDK install into its "default" location, trying to change that may result in read/write permission errors. Do not try to install it as root or into the program files folders, it should install into your %localappdata% folders within your user account. If your user folder is located on a network mounted drive that may also cause problems.
