Software Archive
Read-only legacy content
17061 Discussions
The build failed for ios
Peter_N_
I have a problem creating iOS apps . Follow the instructions
- Produced in windows
Failed Build
Brandon_K_Intel
This is our legacy build system. Would you attempt to update your app to our Cordova iOS build system? Our legacy builders are no longer being updated.
Peter_N_
This means that the application will not go to make for iOS ? How can I fix this error to make it work?
John_H_Intel2
Please use the Cordova iOS builds.
Peter_N_
Use the Cordova IOS build :
John_H_Intel2
Make sure the bundleID you gave the XDK matches what you created for the provisioning profile on apples developer portal.
Peter_N_
Bundle IP it is ok. Controlled more times - more video manuals.
John_H_Intel2
I do not understand what you are asking here.
Peter_N_
How do I create iOS applications. I followed the instructions but it's not working . When creating writes error - Failed Build = 1 image. We apologize for my English language
Amrita_C_Intel
Please use this article for the instructions on how to build ios apps.
https://software.intel.com/en-us/xdk/docs/building-cordova-ios-apps-intel-xdk
Peter_N_
Hi, I used the manual . Unsuccessfully . Still lists the same error
John_H_Intel2
For Cordova builds, you need to enter the bundleID, exactly like you entered it on the apple developer portal. You DO NOT need to add the prefix that apple assigns, which is   JV3.....KV
Remove that from your bundleID in the XDK, re-upload and try to build again.
Peter_N_
Bundle IP is fine . I do not know where he could be a problem.
John_H_Intel2
Are you sure you are using a DISTRIBUTION certificate and a provisioning profile that is associated with that certificate?
Are you able to build a simple iOS cordova app?
Peter_N_
I'm sure you use the correct certificate. I can not not create any iOS Apps = always gives the same error = 1 file
John_H_Intel2
Can you post a screenshot of  the issue you are seeing?
Peter_N_
filmed two videos in a row
471393
John_H_Intel2
1. The first video the (at least the first issue) issue is that you correctly created a distribution certificate, however, whatever provisioning profile you have included is not valid. You must make the provisioning profile AFTER you make the distribution cert. If you look at the apple developer portal, it will say that the provisioning profile is Invalid/Expired.
2. The second video is way off. There is a difference between the Cordova build (first video) and the Legacy builds (part of the second video). When you click the build tab, you are given the option to build Cordova or Legacy builds. The Legacy builds will soon be going away all together, so stay away from them. They are old, outdated, and not really maintained, hence the removal soon.
Stick to building the Cordova iOS app and try giving what I told you in step 1. a try and report back with results.
Peter_N_
I do not understand good English . I tried the first step but does not function. Could you first step developed ? Thanks
John_H_Intel2
Can you try following the steps outlined in this doc?
Peter_N_
I went step- by-step guide (https://software.intel.com/en-us/xdk/docs/building-cordova-ios-apps-intel-xdk) - does not work. I also tried a new blank app - does not work
