Software Archive
Read-only legacy content
17061 Discussions
The -vec-report and -par-report don't bring any messages [XL#Akio]
Akio_Yasu__Intel_
I am tesing Parallel Composer Update3.
I found /Qvec-report and /Qpar-report emit no useful messages.
What I did on command line is as below using int_sin.c default sample.
> icl int_sin.c /QxSSE3 /Qvec-report3 /Qparallel /Qpar-report3
This command line is used to give us some related information in 11.0 Compiler.
Akio
KitturGanesh
Hi Akio,
Yes, it looks like a problem as when I compiled I didn't see the messages that I got when compiling in 11.0. Will follow up on this and will post as soon as there's any update.
-regards.
KitturGanesh
Hi Akio,
There is a bug with the vectorizer and parallelizer reports. To get those visible, you need to use /Qdiag-enable:vec,par until you get an update with the fix.
There's a tracker that is filed on this and I'll let you know as soon as there's an update on the fix, appreciate much.
-regards,
Kittur
Akio_Yasu__Intel_
Hi Kittur,
Thank you for your reply.
I tried /Qdiag-enable:vec,par and made sure it works with that option.
I wait for the fix then.
Akio
KitturGanesh
Hi Akio,
This issue is fixed in the latest release (Composer 2011 update 1) which you can download from the https://registrationcenter.intel.com/RegCenter/. Appreciate your patience through this.
-regards,
Kittur
