Software Archive
Read-only legacy content
17060 Discussions
There is no CODE and DESIGN buttons
Aleksander_D_
I am a beginner in XDK. I created my first empty project from the list of default projects and did not find CODE and DESIGN buttons on DEVELOP tab. I use Windows 7 on Intel 32bit processor. What I have to do to make them visible and continue my work? Help for the beginner :)
Rakshith_K_Intel
The design option only shows up if you have checked the "Use App Designer" option when starting a new project from templates. If not develop tab is "code" by default.
Rakshith_K_Intel
Aleksander_D_
Thank you very much. Thank you for so quick answer too. It was indeed. But more two questions I found to myself and please to answer on:
  1. It is true what you explained but only when I choose Start a new projects/Templates/Blank. When I choose Start a new projects/Layout and user interface there is no checkbox Use App Designer. Tell me why please? Are these layouts closed to redesigning?
  2. Is it any possibility to restore/show/achieve CODE and DESIGN buttons in project created without earlier Use App Designer checked? Does it mean I can't work on projects without design mode no more?
Rakshith_K_Intel
You have to start project with "App Designer", u cannot enable later.
Layout template does not have "App Designer" option anymore, you have start blank project with "App Designer" and then create the layout using the design tool
Aleksander_D_
Thank you very much. Regards from Poland.
bharat_b_
Well in that case templates won't serve any purpose for kick starting the project.
Earlier it used to help a lot.
