Software Archive
Read-only legacy content
17060 Discussions
pending when generate a new Proj.
Wei_H_Intel
HI,
i am location in xi'an China. the issue i meet is the loading is very slow and when i generate a new Proj.
on Samples and Demos  item of (HTML5 companation HYBRID MOBILE or WEB APP),  select one example like (touch Notifier)  and continue button .
it's always pending on download / generation page , the code never generate successful.
do you think it's a Local internet connection issue or tool issue ?
thanks !
He Wei
Zhen_Z_Intel
Hi, Wei. This problem would be due to a slow connection between XDK server and your location. Some of XDK services are hosted on AWS, that might be the main reason that you cannot access resources. Unfortunately, there can be long delays to parts of Asia by accessing online resources.
You can also find those samples on github. There would be many HTML5+Cordova/HTML5 open source examples may helpful to you. Here is the link of "Hello cordova sample", https://github.com/gomobile/sample-hello-cordova .You could download and import this project into XDK. Hope it could help you.
