Software Archive
Read-only legacy content
17061 Discussions
Two Mac's using 3088, same login, different list of projects
Dan_K_
I use two Mac's; a desktop and laptop. I've updated XDK to 3088 on both. I then did some work on my laptop - created a new project, deleted others. When I fire up XDK on my desktop, the new list of project isn't there??
I've logged out and restarted from scratch. No joy.
Any ideas?
-dk
Swati_S_Intel1
You can find global-settings.xdk in ~/Library/Application Support/XDK/. This file contains a list of projects on your machine. When you have two different installations on two different machines both will have different global-settings.xdk hence the list will appear different. You can copy this file over to the other machine as long as the install locations and the paths to the projects are same.
John_H_Intel2
This is the expected behavior. The XDK does not sync your project files across multiple computers. You can use git/dropbox/other to do this for you.
Dan_K_
I guess I didn't explain it, sorry.
I keep the project on Dropbox. In the past, before 3088, both Mac's saw the same list of projects. If I created a project on one Mac, it would be in the project list on the other Mac.
John_H_Intel2
Hmmmm, not sure how that is possible unless you also have the global settings file sync'd with dropbox. For me, its found here, C:\Users\jphughes\AppData\Local\XDK\global-settings.xdk
Dan_K_
The only thing I've done is install the 3088 update on both machines. I'll try deleting XDK from one machine and reinstalling.
Dan_K_
I uninstalled XDK, downloaded a new dmg, reinstalled, and logged in. None of my projects show.
Anusha_M_Intel1
While you did an uninstall, did you ask Intel XDK to remove your project settings? This clears your global-settings.xdk file. The list of projects displayed are fetched from this file. Can you look for this file in your system and see what projects are included in it?
Like John said unless your global-settings.xdk file is synced via dropbox, its not feasible for both machines to see the same projects.
Dan_K_
Where do I ask to have project setting removed? I don't see a "global-settings.xdk" file. I'm on a Mac.
Swati_S_Intel1
Dan_K_
Thanks. Got it.
