Hi, all. Our lab plans to buy an Intel Xeon Phi Coprocessor to speed up. However, I still have two important questions in mind (not quite sure of) before buying it
1. Is Intel Xeon Phi Coprocessor supported for Windows system?
I wonder this because from "Intel® Xeon Phi™ Coprocessor Developer's Quick Start Guide", it says "Host - The Intel® Xeon® platform containing the Intel® Xeon Phi™ Coprocessor installed in a PCIe* slot. The operating systems (OS) supported on the host are Red Hat* Enterprise Linux* 6.0, Red Hat* Enterprise Linux* 6.1, Red Hat* Enterprise Linux* 6.2, Red Hat* Enterprise Linux* 6.3, SUSE* Linux* Enterprise Server SLES 11 SP1 and SUSE* Linux* Enterprise Server SLES 11 SP2. The user will have to install the OS.". Seems it only supports Linux system. However, most of our work are done on Windows.
2. How fast speed can be given by Intel Xeon Phi Coprocessor? How much modification need to be done to change original code to be running well on Intel Xeon Phi Coprocessor (using Intel Parallel Studio XE 2013)?
From Breakthrough Performance section, it says it can only can up to 10x (even below this for different situations). How much modification need to be done to change original code to be running well on Intel Xeon Phi Coprocessor (using Intel Parallel Studio XE 2013) in order to achieve such performance (10x)? And what further do I need to do if I want to achieve higher performance (change code to parallelism)?
Hope you guys can give me more details on them. Thanks in advance. :)
Tommy - more info is now available.
Hi Kathy, many thanks for this useful info. :)
