Software Archive
Read-only legacy content
17060 Discussions
Unable to check Internet Connection
Remi_I_
I'm currently trying to check if my app user is or isn't connected to internet.
I've added the plugin Device,Network Information.
This works completely fine in the emulator but when I test in through WIFI on a iPad and a HTC phone the alert does not work.
Code I am using is below.
document.addEventListener("deviceready", onDeviceReady, false);
function onDeviceReady() {
alert(intel.xdk.device.connection);
Diego_Calp
Valued Contributor I
The api intel.xdk.device is retired, so is not advisable to use it. Here you have more information:
https://software.intel.com/en-us/xdk/docs/intel-xdk-api-cordova-plugin-methods-properties-events
One alternative is
https://github.com/apache/cordova-plugin-network-information
Diego
Remi_I_
Hi Diego,
I already have the plugin network-information.
I tried to use this code as listed below. However this now no longer works in the emulator or test.
 checkConnection();
            function checkConnection() {
                var networkState = navigator.connection.type;
                var states = {};
                states[Connection.UNKNOWN] = 'Unknown connection';
                states[Connection.ETHERNET] = 'Ethernet connection';
                states[Connection.WIFI] = 'WiFi connection';
                states[Connection.CELL_2G] = 'Cell 2G connection';
                states[Connection.CELL_3G] = 'Cell 3G connection';
                states[Connection.CELL_4G] = 'Cell 4G connection';
                states[Connection.CELL] = 'Cell generic connection';
                states[Connection.NONE] = 'No network connection';
                alert('Connection type: ' + states[networkState]);
Diego_Calp
It is working form me, both in emulator and in App Preview in an iPhone.
In Emulator in my Mac, the alert says Ethernet connection.
In App Preview, gives wi-fi connection. If I turn off wi-fi, says No network connection (I expect 3G, but no).
What I did is, I an HTML5+Cordova project I added the Network Information plugin from Core Plugins, drop a button and add to the click event your code above.
The plugin is version 1.2.0 and set android permissions to android.permission.ACCESS_NETWORK_STATE
Diego
