Software Archive
Read-only legacy content
17060 Discussions
Unable to upload the project files
Hamilton_Tenório_da_
Valued Contributor I
I am triyng to build an existing project and I am receiving the message "Unable to upload project files". I checked all the assets and it seems OK.
The error message shows:
ERROR (-7) from "client:upload-manager": Error in zipping package asset files: .
Error at new ComponentError (C:\Users\Hamilton\AppData\Local\Intel\XDK\xdk\core-modules\public\component-error.js:17:1122) at makeError
(file:///C:/Users/Hamilton/AppData/Local/Intel/XDK/xdk/components/client/upload-manager/upload-manager.js:17:170) at getComponentError
(file:///C:/Users/Hamilton/AppData/Local/Intel/XDK/xdk/components/client/upload-manager/upload-manager.js:17:265) at
file:///C:/Users/Hamilton/AppData/Local/Intel/XDK/xdk/components/client/upload-manager/upload-manager.js:17:21929 at _rejected
(file:///C:/Users/Hamilton/AppData/Local/Intel/XDK/xdk/node_modules/q/q.js:844:24) at
file:///C:/Users/Hamilton/AppData/Local/Intel/XDK/xdk/node_modules/q/q.js:870:30 at Promise.when
(file:///C:/Users/Hamilton/AppData/Local/Intel/XDK/xdk/node_modules/q/q.js:1122:31) at Promise.promise.promiseDispatch
(file:///C:/Users/Hamilton/AppData/Local/Intel/XDK/xdk/node_modules/q/q.js:788:41) at
file:///C:/Users/Hamilton/AppData/Local/Intel/XDK/xdk/node_modules/q/q.js:604:44 at runSingle
(file:///C:/Users/Hamilton/AppData/Local/Intel/XDK/xdk/node_modules/q/q.js:137:13)
I deleted the plugin folder and recreated it. I remove the files from the server too. No success.
I tested others projects with similar plugins and they work normally.
What I can do to solve this? What means these errors? Thanks.
PaulF_IntelCorp
Hamilton -- did you review this thread? https://software.intel.com/en-us/forums/intel-xdk/topic/673452 Perhaps there's something in your project file that is causing the problem.
I had checked that post before. No success.
The solution was create another project, copy everything to the new one. Now is OK. I do not understand why... This was an old project, builded several times before.
This workaround works. It is a solution.
