Software Archive
Read-only legacy content
17061 讨论
Unfotunately, app has stopped
Farhan_I_
初学者
422 次查看
package com.example.qao;
import android.support.v7.app.ActionBarActivity;
import android.os.Bundle;
import android.view.View;
import android.widget.Button;
import android.widget.TextView;
public class Main extends ActionBarActivity {
     int counter;
     Button add, sub;
     TextView display;
    @Override
    protected void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.activity_main);
        counter=0;
        add= (Button)findViewById(R.id.button1);
        sub= (Button)findViewById(R.id.button2);
        display=(TextView)findViewById(R.id.textView1);
        add.setOnClickListener(new View.OnClickListener() {
            @Override
            public void onClick(View v) {
                // TODO Auto-generated method stub
                counter++;
                display.setText("Your Total Is "+ counter);
        sub.setOnClickListener(new View.OnClickListener() {
            @Override
                counter--;
                display.setText("Your Total Is " +counter);
this is my program it shows no error on eclipse but when i run the program emulator doesn't run it emulator shows a message "unfortunately app has stopped" someone please find the mistake in it. I just started learning android development but now i am stuck with that problem.
0 项奖励
1 回复
Jorgesys
初学者
422 次查看
To solve this kind of problems is very important to post the messages displayed in LogCat, otherwise is very difficult to get a solution :(.
for my experience if you have the message: ""unfortunately app has stopped" the two main causes are:
1) any of this elements:
1 add= (Button)findViewById(R.id.button1);
2 sub= (Button)findViewById(R.id.button2);
3 display=(TextView)findViewById(R.id.textView1);
doesn´t exist inside the layout: "activity_main.xml"
2)  probably your activity is not registered inside the "AndroidManifest.xml".
0 项奖励
回复
